Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 04:19 PM
Choctaw Bob's Avatar
Choctaw Bob is starting off with a positive reputation.
Engine Oil Pressure Gage?
In the Ford Service Bible found on this web site, the following description of the Engine Oil Pressure switch appears:
"This switch controls the oil pressure gage on the instrument panel. When pressure is above 7 psi the gage will read normal and if the pressure drops below 6 psi the gage will read 0."
This means that the oil pressure gage on the instrument panel is worthless. It's only purpose is to keep people from complaining about low oil pressure. Any of us who attempt to pull a 12,000 trailer across the Rocky Mountains with 7 pounds of oil pressure is in for a surprise.
__________________
03 6.0 SC Short bed 2WD Auto
Preditor, Gages, K & N FIPK
  #2 (permalink)
Old 02-15-2004, 06:01 PM
"Luke" SdeS is starting off with a positive reputation.
Gee, that may well be the same for a car..........
__________________
Just A Thought...............on...............My Perceptions................
Support FTE by supporting it's sponsors!
  #3 (permalink)
Old 02-15-2004, 06:09 PM
I read that in a magazine last year ithat all Ford vehicles had this type of oil pressure gage. Didn't believe it until now.
__________________
  #4 (permalink)
Old 02-25-2004, 05:01 PM
Lariat is starting off with a positive reputation.
Re: Engine Oil Pressure Gage?
Wonder if there is a replacement sending unit for the switch? "Emtabmm, Any comment?? I for one don't want to have an idiot guage.
Lariat
__________________
2003 F 250 Lariat Super Duty 6.0L 6 speed, with all the goodies
  #5 (permalink)
Old 02-25-2004, 06:08 PM
IB Tim's Avatar
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
IMO it fills a space on the dash
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #6 (permalink)
Old 02-25-2004, 06:20 PM
International Tech's Avatar
International Tech is starting off with a positive reputation.
just a thougt but i wonder what would happen if someone were to swap the oil pressure sending unit from ford to an International sending unit and see what happens. The oil pressure gauges in the Internationals read in psi and are dead on as far as accuracy. just wondering
BTW stock oil pressure gauges in Fords are like tits on a bull USELESS!
  #7 (permalink)
Old 02-25-2004, 08:11 PM
slc10844 is starting off with a positive reputation.
I wonder if an earlier model SD, like a 99, worked the same way? If not, it maybe trying an earlier sending unit to see if it works. A International sender may not be compatible with Ford instruments.
__________________
08 F-150 FX4 Supercab 5.4 Auto 3.55 LS
  #8 (permalink)
Old 02-25-2004, 10:10 PM
yea sorry bout that had a brain fart! knew they were not compatible.
  #9 (permalink)
Old 02-25-2004, 10:13 PM
IB Tim's Avatar
Administrator
Surley does not mean we cannot find a way around this problem, no need to give up.
There has go to be a way
__________________
Administrator
  #10 (permalink)
Old 02-25-2004, 10:22 PM
never give up
  #11 (permalink)
Old 02-26-2004, 11:58 AM
RJB1's Avatar
RJB1 is starting off with a positive reputation.
I would guess it will take adding a resiter in-line if the sending unit is replaced. Question number one is does the wire from the guage come directly from the sending unit or through the computer?
A while back I saw a post about the Instrument cluster diags. You hold down the trip reset button while starting the vehicle then cycle through numerouse readings one of those could be an accurate pressure reading. I know it will give you barometric pressure, true rpms, speed and other codes that are yet to be fully defined by us on the forum.
__________________
1997 F150 4x4
1972 F250 4x4 (money pit, but fun)
1971 F100 2WD donor
2007 Mustang 4.0
2000 FLSTF (Fat Boy)
  #12 (permalink)
Old 02-28-2004, 08:53 AM
I bought a Auto Meter oil pressure gage. When I removed the Ford sending unit from the manifold between the oil filter and turbo, I discovered that the fitting was an AN type thread. Today I will get the parts and install the new gage. The Ford gage Sending unit must remain (put a T between the sending unit and manifold) because the sending unit must read oil pressure or the computer will shut the engine down...
I will post again when I get done with photos.
__________________
  #13 (permalink)
Old 02-28-2004, 09:03 AM
Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE.
Bob, good idea installing a "real" oil pressure gauge!! One thing
you can do that will eliminate putting a T on the sending unit, is
just ground the wire going to the OEM oil sending unit "switch".
Of course, you loose the safety feature, of the engine shutting
down with loss of oil pressure....
I changed out the OEM oil sending unit "switch", replacing it with an analog type of sending unit, and I can now see fluctuations
in oil pressure with my OEM gauge. This was on a Ranger 3.0L,
I'm sure the same thing will work on any Ford with the "IDIOT
LIGHT" oil pressure gauge. I've seen previously that there is a
20 OHM resistor in series with the gauge to the sending unit,
but when I pulled my instrument panel, I didn't have the resistor.
If you do have the resistor, you need to short it out with the analog sending unit...
  #14 (permalink)
Old 02-28-2004, 09:14 AM
IB Tim's Avatar
Administrator
When this is complete, maybe it would be possible to post a complet list of all the items needed to have a real guage.
All in one post with instructions will be great.
__________________
Administrator
  #15 (permalink)
Old 02-28-2004, 02:01 PM
Next week. The parts store was closed today and they are the only one around here.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
