Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 02:37 PM
loscroce is starting off with a positive reputation.
Question 88 7.3 Hard Start Problems
Recently purchased an 88 E350 with7.3 IDI. Runs and pulls like a bat outta hell, but always has a problem starting when cold. Doesn't matter whether its warm or cold out, first start in the morning can take up to 10 trys. Once its running, no more start problems for the rest of the days use. I have read that this a problem with this particular engine, but that there are remedies. I have replaced the glow plugs, glow plug relay, injection pump, fuel filter, starter, 2-new batteries. All pressures and electrical stats are on the money. Have records for her for the last 10 years and every year it got a new starter, batteries, glow plugs. Don't want to continue this, but solve the problem. Love the van and would like to keep her, but have to solve this problem or its bye bye for her. Any help is greatly appreciated. Thanks in advance for any responses.
  #2 (permalink)
Old 02-15-2004, 03:24 PM
ltfox's Avatar
ltfox is starting off with a positive reputation.
One thing to check is the injector return lines. If they are bad the will leak and let air bleed back into the system. Most start to rot and crack after a while.
__________________
1994 F-250 PSD EC 4x4 5spd 4:10's, gutted ebpv, 3-4"Dp, 4"exhaust, HPX, TYMAR intake,1.0 a/r housing, 3pos TWildman chip
1996 F-250 PSD CC SB 4x4 5spd 4:10's 6oh intercooler, 3"dp and no more cat, Tymar intake & HPX, .84 a/r housing, 203* stat, 4pos Wildman chip!
  #3 (permalink)
Old 02-15-2004, 06:32 PM
Thanks for the info. I just ordered a set from Dieselmann's site. Let you know if it works out.
  #4 (permalink)
Old 02-15-2004, 07:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Hope you got the O rings as well, once you disturb the return tee's they will leak as well.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 02-15-2004, 07:39 PM
Mike 84 is starting off with a positive reputation.
test for hard starting
Do you by chance park at night with the front pointed uphill? I had an 88 F-450 that if parked overnight in this manner would be very hard to start the next morning, summer or winter. If parked with the front downhill it would start like it is supposed to. If yours will start after trying this you have a leak somewhere in your fuel system allowing air to enter when front of vehicle is sitting higher than rear of vehicle.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
