Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 10:34 AM
90'f-150/300ci/help is starting off with a positive reputation.
wut engine iz mine/replies pleez
so whats crackin,
my problem is first of all how do i tell what 300 motor i have. You know, i see everything from like 3.2L to 4.9L. I roll in a 90' f150. Trying to fix problems but haven't quite learned much about the whole EFI vacuum regulated BS. sure is a strong engine though with an exhaust leak and like a misfire at low RPM and idle. Seems that everybody has the sputter affect with these engines. I am thinking the sputter might be my coil?? Also, maintenance on the EFI, what to do. Everything helps, thanks.
Ya, one more thing, there is this bar on the top of the engine that looks like it has injector deal on each cylinder, believe this is some kind of air return for emmissions, one of the injector deals has been cut and welded shut. Is this bad?? Maybe someone has similar problems and wants to sharetheir thoughts!!!
  #2 (permalink)
Old 02-15-2004, 11:04 AM
true4.2 is starting off with a positive reputation.
I guess it sounds like you have the 300 I6 in your truck correct? There is another forum here that deals specifically with those engines. I would check in that forum also.
Just go to the forum titled :Inline Six:
__________________
--Joseph--
'08 F350 6.4L
Hot Shot Hauling Truck
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
