Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2004, 09:16 AM
supercab79 is starting off with a positive reputation.
Question 79 250 4x4 pwr steering input shaft leak
After pressure wasking the box and frame I could finally see that I had not a hose or line leak but that the fluid was pouring out of the input shaft seal on the steering box.
Changing the box would probably be the easiest thing to do but would prefer to change the seal if possible now the only problem is that i wasnot sure as to what worm gear back lash or bearing preloadeds I would be getting into if any one has any info I would really be GREATFUL.
THANK YOU
  #2 (permalink)
Old 02-15-2004, 04:12 PM
bob arrington is new and has a neutral reputation at this point.
i may be wrong , but if that is the is th seal for the steering colum side , it can be replaced by removing the jam nut ,prying the old one out and tepping the new one in,something else you can do is add seal rejuvinator to your power steering and see if that will swell it up ,good luck,bob bob
  #3 (permalink)
Old 02-15-2004, 08:54 PM
thanks for the reply
Thanks Bob for the reply this forum is great.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
