Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 02-14-2004, 10:26 PM
calimove calimove is offline
Garage is empty, add now
calimove is starting off with a positive reputation.
TIRE SIZE ? 315/70 17" question
I have been reading all I can on this and I have come accross some posts talking about putting 315/70 17 on the f150s but no one i have seen has said it was with out without a lift kit. This is my bottomline question. I have a 2000 F150 4x4 with 5.4l. I know the 285/70 17 will fit on the truck without an issue but for the price I can get 315/70 17 for about 100$ dif. I want to know if I can put these on the truck without a lift kit. I dont believe the stock wheels will work since many say the max for the factory 17s is the 285/70 17. So i wonder what width, offset, and size would i have to go with, if i can, to put a set of 315/70 17s on my pickup? What are your thoughts on this? thanks
  #2 (permalink)
Old 02-15-2004, 11:27 AM
will a set of 17x8 be wide enough or does it have to be a min of 17.8.5?
  #3 (permalink)
Old 02-15-2004, 04:50 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
I don't think that you would be able to turn the wheel without a lift kit. Those tires are over 35" tall. I would use a 17x9" wheel.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 02-16-2004, 02:26 PM
KevinW KevinW is offline
KevinW is starting off with a positive reputation.
Thumbs down 315's
A friend just installed 315\70\17's after a 3" body lift using 8" wheels. Looks like it would rub otherwise.
  #5 (permalink)
Old 02-16-2004, 09:25 PM
tbalan tbalan is offline
tbalan is starting off with a positive reputation.
You might try 305's. I saw a set on a truck today and asked the guy if they rubbed, he said they barely touched his plastic air dam on the bottom of the bumper when the wheels were turned all the way.
I have 285's on my extended cab and i really like them alot, but the 305's look better.
Tags
1785, 2001, 2004, 2857017, 31570, 3157017, 4x4, f150, f250, fit, heritage, lift, putting, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
