Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2004, 10:20 PM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE. ford390gashog has a very good reputation on FTE. ford390gashog has a very good reputation on FTE. ford390gashog has a very good reputation on FTE.
starter
i tried to start my 75 ford f 150 turned the key but nothing the starter didn't even make a noise is this the starter or something else also can you test a starter by hooking the positive lead on the starter to the pos on the battery
  #2 (permalink)
Old 02-14-2004, 10:34 PM
Colo79Ford is starting off with a positive reputation.
Did you try doing a forum search for starter troubleshooting? I know there are a few posts in the past about starter problems... my first post was because of my starter.. I am pretty sure you will find what you are looking for. But if not, i know someone will put up a post that will help you too...
---JOHN
__________________
My truck
  #3 (permalink)
Old 02-14-2004, 10:40 PM
ejustin3724 is starting off with a positive reputation.
well first check battery if yes
is your starter solenoid working?
you can cheak by jumping the side closes to the battery with the pole closes to it if nothing
check connections if still not working take starter out and have tested. It's not all bad, if the starter is bad you have your core there already and it's just two bolts. Bonus
before all this make sure all connections are clean and tight.
Just last week I leaned some thing new. A 460 is hard to start when hot using a 4? gage wire. Not enough amps. I took it to a shop last summer and they told me it was a weak starter. What they didn't know is that it was a new starter. I guess they didn't get underneath to check connections. Any ways i took a 2 gage wire off another truck a weekago and now it starts like it should. Funny how we learn things. If I would have gotten a bigger wire it you have saved me a new starter and a trip to the shop!
__________________
'68 F250 Crewcab 2WD 390/NP 435
'74 F350 Super Camper Special
'74 F350 Crewcab 2WD 460/C6
'94 F350 Crew LB 4x4 460/E4OD
oh...and a car
  #4 (permalink)
Old 02-15-2004, 12:54 AM
bob arrington is new and has a neutral reputation at this point.
thats real good info, many thanks , respectfully,bob
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
