A/C ? Why does the A/C run all the time when....
Why does the A/C run all the time when you have the vent selection set to panel, floor or panel/floor? I read the manual and it says that at low outside temps the A/C will not run. But if you have the temp gauge set on a cold setting it will run automaticly if it is hot out side. Mine seems to run all the time regardless of the temputure outside or regardless what the temp selection is set to. Is that right? How does yours work?
Thanks
Chris
Thanks
Chris
The a/c should only run when in the ac position or when you choose in defrost.
Unless you have temperature select model,was that avaiable in the lariat model ? then it will run and cool to mantain the temp you set it at
what makes you think its running ?
because you here it click on /of
or is it truly blowing cold air?
Remember there is a low refrigerant switch in the system that warns you of low level by cycling the compressor off/on
you could have a bad thermostat switch in the dash that is shorted closed!
the way to chk for it is to set the ac to run with the temp select in the middle of the temp.
make sure compressor is running/let run for 4mins.(you'll here it click)
then turn the temp selection switch towards warmer
did the compressor shut of ?? if it didn't then you have a bad temp switch.
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Rich
not with rocks
Your A/C should not run in Panel (face) or Floor (foot). Only all the others.
In low temps it WILL run although it takes a while for it to kick in. And it will run when you select warm air too. It serves to dehumidify the air.
If yours runs all the time; it's broke.
>By running "all" the time, the system stays lubricated.
>Thus, leaks and compressor failures occur much less than
>they used to.
Yes...right again
It keeps those seals lubed too so they don't dry up and rot with no use in 6 months (here in OR) (we hibernate)
>they used to.
Yes...right again
>Sure wish you'd keep that cold air up North. Last week I
>was running the A/C 'cause it was 70+ and pretty hot with
>the sun shining in the truck... yesterday morning it was 7°
>with a wind-chill of WAY below zero
NoMo,
7° How did you do that? The little " ° " thingy.
Yer so brainy!!
NoMo,
Yer so brainy!!
