homemade fifth wheel hitch - Ford Truck Enthusiasts Forums
Old 02-14-2004, 07:55 PM
bob arrington bob arrington is offline
bob arrington is new and has a neutral reputation at this point.
Smile homemade fifth wheel hitch
ive traded some work for a fifth wheel camp trailer ,25' and was thinking about making my own hitch , it wouldnt have to be fancy, just strong . i have tools, welders, and good steel.has anyone done one or seen one done that could give me some ideas,thanks,bob
Old 02-15-2004, 01:08 AM
believer45 believer45 is offline
believer45 is starting off with a positive reputation.
My bet is you could buy one for less than you could build one. I doubt you could build the fifth wheel itself although a decent fabricator could make the mounts. You would need to buy the fifth wheel itself and the legs it mounts on. I think it would be very difficult to hand make the jaw kit and such to do the latching and if there was a problem with the hitch you would be on the hook as the manufacturer.
I supervise in a maintenance shop for a large trucking company and buying a new fifth wheel is in the $1300 range even with our national account buying power. I would guess a decent used one would be around $400 - $600 and you would still need the factory feet it mounts to.
You can search http://www.hitch-web.com/ to see if they can come up with anything.
http://www.hitch-web.com/items.asp?O...O4ID=11&O5ID=1 is an entry level Hidden Hitch thay may work.
Dave / Believer45
Old 02-15-2004, 03:38 AM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
If you're talking about making the frame mounts and rails the hitch attaches to, and you seem to have some fabrication skills then I don't see a problem with that. I don't forsee a home-shop fabricator making the actual 5th wheel hitch lock jaws and plate mechanism. You could save some money making the mounts and look for a used hitch like Believer said. He quoted prices for 18 wheeler hitches. The hitches RV'ers use in pickups are not as expensive. I see used ones for sale for $200-$400. I would buy the hitch first and then make the mounts for that hitch.
Old 02-15-2004, 12:49 PM
many thanks,respectfully ,bob
Old 02-16-2004, 05:35 PM
Bob, check
http://www.ford-trucks.com/forums/sh...hreadid=205289
Another member here is selling a 14,000 lb hitch and tailgate for $175.00.
Might be right up your alley.
Dave / Believer45
Old 02-17-2004, 11:06 PM
way cool, thanks,bob
Fifth wheel hitch dilemma?? EcoboostKev Fifth Wheel & Gooseneck RV Towing 34 06-13-2016 09:21 AM
Turnover Gooseneck hitch? pwjackson42 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-08-2014 03:34 PM
Ford 5th wheel hitch in standard bed woodbutcher85 1999 to 2016 Super Duty 12 11-12-2011 12:16 PM
fifthwheel goose neck combo hitch bennyhona Fifth Wheel & Gooseneck RV Towing 8 11-30-2008 02:29 AM
Clearance between truck bed & fifth wheel. Scott Blackwell 1999 to 2016 Super Duty 2 07-09-2006 10:53 PM
Tags
blocks, fifthwheel, hicth, hitch, hitches, home, homemade, level, made, plate, truck, wheel, youtubecom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
