Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2004, 05:36 PM
truckertony is starting off with a positive reputation.
engine knock @2000rpm
well im not sure what this one is if i hold down the gas peddle @2000 rpm's while in park i get clunking noise from engine also if i let off the gas peddle and immedietly press down again some times it will clunk when its cooling down she clunks dealer put new cats on but no difference oh yey its a 2003 f-150 sc 4.2 liter i have made post on this same issue but no response so i figured i would word it a little different just maybe someone has had this problem.
  #2 (permalink)
Old 02-14-2004, 07:52 PM
BlueOvalFitter is starting off with a positive reputation.
The clunking noise you are hearing when your truck is cooling down are the catalytic converters.They get so hot when running that when you shut off the engine the rapid cool down makes the steel "creak". Mine does it all the time.
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
  #3 (permalink)
Old 02-23-2004, 05:43 AM
mikelehmann is starting off with a positive reputation.
sound like you could have lose flywheel or converter bolts. pully's will also makes this noise if lose. take a good look all around
__________________
2002 E-350 superduty extended 5.4
2004 F-350 Crew 4X4 5.4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
