Reese Titan Hitch
Reese Titan Hitch
Hey all!
I just ordered a Reese Titan V Class V 2.5" receiver hitch for my 86 F350. I've also ordered their "Titan Strait Line System" which is a combination weight distribution and sway control system.
I know it's a bit late to ask, but has anyone had any experience with this particular hitch or towing system? Any issues?
I'm planning on hauling a 29ft toy hauler (tow behind) with this, with a max load of 11,500lbs. This is within my GCWR of 18,500 for my rig. I doubt if I'll ever hit over 9,000lbs in reality as I'm just hauling a few ATVs. Max tongue weight is 1250lbs , which is under my 1400lbs rating for the hitch.
Anyways, just curious if anyone has had any positive or negative issues with this set up.
Thanks!
Thanks!
I haven't used the Reese straight line/dual cam, but alot of people on other towing forums are posting that hitch or the Equal-I-Zer hitch are two best choices for sway control. The Titan reciever seems to be a good hitch. I considered it, but bought a Curt Magnum instead, only because the price was about 100 dollars less and rating was about the same. The Titan, I think, is built better than my Magnum because it goes further forward into the frame. I doubt you will be disappointed with that hitch.
snowdog79
Fifth Wheel & Gooseneck RV Towing
08-08-2013 10:38 AM
snowdog79
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
07-09-2013 08:40 AM
AlwaysBulkin
06-29-2011 08:36 AM
