Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-13-2004, 11:19 PM
76150lbx is starting off with a positive reputation.
72 302 into 76
Will 72 302 eng & mounts , auto trans ,mounts, drive shaft, work on a 76 frame our do i need to find 73 ?
  #2 (permalink)
Old 02-14-2004, 02:31 AM
kermit's Avatar
kermit is starting off with a positive reputation.
the wheel base will determine whether that driveshaft will work....longer wheel base, 3 piece driveshaft (front part, carrier bearing, rear part), shorter wheelbase, one piece driveshaft. what motor was originally in the 76. if a 302 or 351w, then motor should drop right in, if something else, might have to find mount towers, and not sure if the crossmember is in different location for the trans depending on 2/4 wd, auto, man....you know, the variables of transmissions.
__________________
kermit, 1973 F250, 2WD, 460, C6
"10 in the tank, 4 on the floor"
  #3 (permalink)
Old 02-14-2004, 12:27 PM
original mtr 360 C6 trans .ican buy complete 72 F100 $600.oo O.B.O C.D.N There is lots of old trucks here on the island i might just hold out till a73 comes up my book says that there is 302 for that year it would be easier to swap i think.
  #4 (permalink)
Old 02-14-2004, 09:55 PM
ejustin3724 is starting off with a positive reputation.
If the original is a 360 you will need to stay with the FE engines. These are 352 ,360, 390 for plug and play. Anything else will take alittle work. i.e. motor mounts, belhousing etc.
__________________
'68 F250 Crewcab 2WD 390/NP 435
'74 F350 Super Camper Special
'74 F350 Crewcab 2WD 460/C6
'94 F350 Crew LB 4x4 460/E4OD
oh...and a car
  #5 (permalink)
Old 02-14-2004, 10:36 PM
ejustin3724 did i mention that gas is 86 cents per liter here 4.5 ltr per gal at 8-9 miles per gal .work is cheap money costly. would love tear down 360 put in 390 crank& rods and go from there but 302 tweaked lightly should give milage that i can live with.
  #6 (permalink)
Old 02-14-2004, 11:01 PM
Didn't see you are from Canada. I would go with a 351W just as good on gas as a 302 but better power. If your set on a 302 then go with a 300/6 about same power with better milage yet. It also bolts up just like the 302/351W combo. However get ready for the mods.
__________________
oh...and a car
  #7 (permalink)
Old 02-14-2004, 11:24 PM
the 351w will be easier to find many rust buckets here cheap. just like the 302 had one in a 70 van intake, headers ,3 speed on the floor from hurst The truck i have sat for last11yrs in carport was used to tow tent trailer may -sept and parked every since new now 2nd owner this is a dad & daughter project. 3yrs till her grad so plenty time!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
