Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-13-2004, 06:15 PM
lilhelppls is starting off with a positive reputation.
Is 90 Bronco II fuel pump bad?
I have been reading these forums for a lot of my ford problems, and they really help. This is my first time asking a question, so any and all help would be great. 90 bronco II 2.9l 4x4. started fine, then one day it stalled and I haven't got it to start since. There is fuel, dry gas in tank. I hear the (intank) fuel pump come on when i turn key. I replaced the fuel filter, I have spark, all fuses are ok. fuel reset button on firewall on passanger side is ok. I just checked the fuel pressure valuve near the fuel injecturs, but nothing came out (air or gas). does this mean even though I hear the fuel pump working, it could still be bad, or do I have another problem? I could use all the help I can get, I am not a pro, just a do it yourself guy. Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-13-2004, 07:34 PM
Ken00's Avatar
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!!
If you cycle the pump a few times and you don't get any fuel at the rail either the line or filter is clogged, or the pump screen is clogged or the pump is bad. Please be careful checking the fuel pressure by pressing the valve on the fuel rail, if you have pressure it will squirt out with some force and distance.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #3 (permalink)
Old 05-12-2008, 01:08 PM
JFaz is starting off with a positive reputation.
I have an intermittent problem with my fuel pump also. When I turn the key to the "on" position, I hear the "click" from the fuel pump but not the pump spinning up. After I find another ride, get picked up, or walk, the problem fixes itself. The next time I go to the truck, the click is there, the pump spinning up is there, and voila! It cranks! It happens every time! Gremlins I swear!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
