02-13-2004, 04:55 PM
First, stop replacing sensors and other parts until you test them.
Now, run KOEO codes, check your timing, and check your fuel pressure. Post your KOEO codes here, and I'll look them up in the 86 (close enough for an 87 2.9) Ford H manual and give you the pinpoint tests.
Last thing - never try to guess gas mileage by how many kilometers you get to an average tank. Fill the tank completely and reset the triptometer. Calculate miles per gallon or liters per 100km when you fill back up based on distance and fuel volume required to refill the tank. Keep a record and you can see if the difference really is significant, or if it's a certain station where the pumps shut off sooner, etc...
