Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-13-2004, 03:41 PM
javi2001's Avatar
javi2001 is starting off with a positive reputation.
How mani oil ???
Hi all, I'm installing an underdash A/C system, I got it from a local manufacturer, the compresor is from a Econoline 1991, inline 6 engine.
My question is, since this is a personal proyect; I don't know how mani oil can use my system, original Ford on that econoline used 9 to 11 onces but I'm using my owns hoses and so.
Is there some way to calculate appropited amount?
Any feedback will be appreciated.
Regards;
__________________
Javi2001@cantv.net
Venezuela
4.9L carby +E4OD +1356 Electric shift T-Case + WARN Auto hub's +Baumman TCS controller, F150, 4WD, 1986!!! will be MFI shortly
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-13-2004, 10:48 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
I would think that you would be ok with that amount.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 02-14-2004, 04:04 PM
javi2001's Avatar
Yes I agree with you but, there should be some way to calculate the exact amount, isn't it???
Some more ideas???
Thanks
__________________
Javi2001@cantv.net
Venezuela
  #4 (permalink)
Old 03-04-2004, 03:56 PM
javi2001's Avatar
No ideas???
__________________
Javi2001@cantv.net
Venezuela
  #5 (permalink)
Old 03-04-2004, 06:42 PM
I've looked and have not found anything that dictates an exact amount based on hose length, etc. Maybe someone else knows.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #6 (permalink)
Old 03-05-2004, 09:32 AM
BandBFord's Avatar
BandBFord is starting off with a positive reputation.
Hose length has very little to do with the amount of oil required by the system. A/C compressor oil is atomized and carried in the refrigerent as is circulates through the system. You should be fine with the amount of oil recommended for the compressor you are using
__________________
B and B
2006 F-150 5.4 "Chrome Edition" SuperCrew 4x4
2006 Mustang GT
2001 Mustang V-6
1999 Mustang V-6
1996 Ford Explorer
  #7 (permalink)
Old 03-05-2004, 01:54 PM
javi2001's Avatar
Ok. Ford Shop Manual 1991 say should be 3 to 5 once in compresor for normal level. I guess should try 8 onces then run for a couple of days then messure oil level in compresor and add if requiered
Any extra will be appreciated. Thanks guys.
__________________
Javi2001@cantv.net
Venezuela
  #8 (permalink)
Old 03-09-2004, 09:10 PM
Ecuri is gaining momentum as a positive member of FTE.
Oil will also collect in the condensor and evaporator. See if you can find a number for total system requirement and not just the compressor. Put 1/3 in evap, 1/3 in condensor and 1/3 in compressor. Too little is catastrophic, too much reduces the cooling efficiency. If guessing, I would guess to the high side. I bet you get R-12 there anyway. GL and MANY happy cool days to you!
__________________
78 F150 408 4v valves/C6
77 F250 390/NP435
99 Explorer daily driver
  #9 (permalink)
Old 03-26-2004, 04:35 PM
javi2001's Avatar
Well finally a did so:
5 Oz in compresor
2 Oz Evap
2 Oz condensor
Everything seems be right, more over, there was a extrange noise prouced by compressor and it dissapear after service. Yes ! here we can get R12 as easy as R134.
Thanks to all.
__________________
Javi2001@cantv.net
Venezuela
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
