Towing capacity of '96 F-250? - Ford Truck Enthusiasts Forums
Old 02-13-2004, 09:07 AM
Frankenstang57's Avatar
Frankenstang57 Frankenstang57 is offline
Frankenstang57 is starting off with a positive reputation.
I just purchased a '96 F-250 4x4 extended cab with the intent of pulling a multi car trailer with it.(it was really, really cheap) It only has a Winsdsor in it right now and is probably a little light duty for the job. It is a once a year thing and I realise it won't be no speed demon. What does Ford rate these guys at pulling a gooseneck? Thanx!
Old 02-13-2004, 10:31 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
You have to give more information.
Exact engine, not just Windsor
Transmission
Rear axle gear ratio
Tire size (if other than stock)
Those items determine GCWR.
From that you subtact the empty weight of the truck and
then subtract the weight of gas, driver, passengers and anything else you are carrying in the truck.
If you have an owners manual, its in there.
I suspect that that truck wont do what you want because a 4x4 extended cab F-250 is so heavy to start with. Since you live at high altitute you also have to remember that you loose at least three percent power for every 1000 feet above sea level without a turbo/supercharger.
Jim
Old 02-13-2004, 06:18 PM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
Since you said "Windsor" engine, I'll assume you have a 351, which is common in F250's of that period. For a single car trailer, if you truck is geared right (4.10), and you're running stock or only slightly oversize tires, you will be able to pull it ok. But a MULTI-car trailer? I would say you don't have enough engine for that. You need a 460 or a diesel to pull that kind of weight.
As an example, my F350 Crew Cab Long Bed 4x4 351 C6 trans, if it had 4.10 gears and stock tires, would be rated at 7700 lbs for a 5th wheel, ~7200 for a bumper pull. Your truck would be rated simillar with same engine and gears, as it weighs almost as much as mine I would think. Most single axle car haulers have a GVWR of 7000 lbs. and weigh 1500 lbs or more empty. The same truck with a 460 would be rated about 2000 lbs more for max trailer weight, if I remember it correctly.
Old 02-13-2004, 08:39 PM
88n94 88n94 is offline
88n94 is gaining momentum as a positive member of FTE.
How far will you be pulling the trailer? What will the approximate gross loaded weight of the trailer be? I am sure you can safely get by with quite a bit more than the manufacturers rating if you arent traveling in mountains or the like. Assuming the drive train and brakes are in good condition, of course.
Old 02-14-2004, 09:32 AM
Ok, it has a 5-speed, don't know the rear gear but it seems pretty low on the hwy. I will probably be pulling a 36ft gooseneck with two racecars, and tools.(probably about 5500 lbs + the trailer) It doesn't have to be fast and I'm not heading over any mountain passes, from Denver to Gainesville.
Old 02-14-2004, 09:48 AM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Base Number of Cylinders: 8 Base Engine Size: 5.8 liters
Base Engine Type: V8 Horsepower: 205 hp
Max Horsepower: 3800 rpm Torque: 328 ft-lbs.
Max Torque: 2200 rpm Maximum Towing Capacity: 10000 lbs.
Drive Type: 4WD Turning Circle: 50.4 ft.
The above ratings assume the extended cab pickup itself is completely empty. No people, no tools, no gasoline. This is how Ford calculated their maximum towing capacity in the 90's.
So, subtract your weight, any passenger weight, your toolboxes and tools, any junk you have in the bed, a bed cap if you have one, plows, pushbars, ladder racks, etc.
Then multiply your fuel capacity (in gallons) by three, and subtract that amount from the adjusted towing capacity.
Then you have a final number that you can actually tow.
An important note is that just because the truck is rated at a specific capacity doesn't mean you can actually tow it. For me, I don't consider sitting in third gear, going uphill at 30 MPH because you're overloaded "towing". Depends on the engine's condition, the torque, the gearing, and what you are actually towing.
I have a 93 F350 and on rare occasions I've grossly exceeded the rated towing capacity of 12,000lbs. Grossly. But I only had to drag that trailer and the bulldozer 11 miles, so I took it slow, was gentle on the clutch, and took my time. It was not a long trip by any means. I just needed the bulldozer here <G>
Towing requires torque, there is no way around it. This is why a lot of commercial applications like dump trucks, tow trucks, trailer haulers, construction vehicles either have the 460 or even better, the powerstroke.
A good buddy of mine has the turbocharged powerstroke, and when he's hauling his race car, spare engines, and other heavy items, on a 6% grade incline, he can actually accelerate from 75MPH and pull away from me, going uphill.
Torque wins. Anyway, hope the ratings above you and associated explaination as to what to subtract helps you out.
Old 02-14-2004, 01:46 PM
mike 01 mike 01 is offline
mike 01 is starting off with a positive reputation.
I had a 94 f250 w/351 and a 5 speed. It had 4.10 gears and 33x12.50 wild country's. I pulled our aluminum gooseneck(20,22? ft. w/2-7000 lb axles) and averaged approx 10,000 lbs of hogs (that was the weight on the ticket-what the hogs weighed after I unloaded them). It worked the truck, but it handled it ok. Be sure you have a brake controller, I didn't the first 3 loads, and it was alot of weight for the truck brakes.
Anyway, just thought I'd mention this.
New guy with a transmission issue Newtoford96 1994.5 - 1997 7.3L Power Stroke Diesel 5 05-29-2015 08:34 PM
transmission question birdman91 1978 - 1996 Big Bronco 2 09-09-2013 11:47 PM
transmission please help birdman91 1987 - 1996 F150 & Larger F-Series Trucks 2 09-09-2013 07:54 PM
help a fella out. birdman91 1987 - 1996 F150 & Larger F-Series Trucks 3 09-09-2013 12:59 PM
'01 XLT Sport V8 AWD - update as i go AlaskanEx Explorer, Sport Trac, Mountaineer & Aviator 105 09-06-2013 05:35 AM
Tags
351, 4x4, 96, bed, capacity, f250, ford, gas, towing, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
