Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #31 (permalink)
Old 05-21-2006, 11:07 AM
jasgeer is starting off with a positive reputation.
Any updates or last thoughts on upgrading the cam on a 460 EFI engine? I have been checking the options and the Comp Cams XE256H-14 (256/268 duration, .490/.495 lift, 114° lobe sep) is the only one actually advertised for stock EFI. The only reason I am wary of it is the wide 114° lobe separation; my experience is that 110° cams run better. Here are alternatives I found:
Lunati 61600 is rated 250/256 duration, .503/.524 lift and 112 separation.
Isky 311256 is rated 256/256 duration, .492/.492 lift, 32 overlap and 112 separation.
Isky 311256/262 is rated 256/262 duration, .492/.488 lift, 39 overlap and 110 separation.
Crane 350501 is rated 248/260 duration, .456/.487 lift.
Crane 353904 is rated 260/272 duration, .487/.518 lift.
Comments?
Jim
  #32 (permalink)
Old 05-21-2006, 01:39 PM
Here is a previous post by DeGideo:
Ford's SVO(now Ford Racing Performance Parts)1993 parts catalog offered a EFI460 cam part # M-6250-T460 with the following specs : 204 degrees duration intake/216 exhaust@.050" lift and .487" valve lift intake/.518" exhaust. Under camshaft footnotes it states : "Increased torque.Smooth idle with good all around performance.Designed for EFI use".They don't offer this camshaft anymore,but the one I put in my 1994 EFI460 engine is a Crane Cams cam with almost the exact specs.The specs are : 204 intake/216 exhaust@.050" lift and .487" intake/.519" exhaust."
The Crane 353904 specs at .050 are 204/216 with alift of .487/.518.
The Comp Cams specs at .050 are 212/219
The Lunati specs at .050 lift would be 207/213.
Jim
  #33 (permalink)
Old 10-01-2006, 03:13 AM
stngh8r is starting off with a positive reputation.
Exclamation
This is a great thread and really just want to keep it going.
Any performance #s from some of you guys that have all the boltons and/or cam setups?
Example: Deen, DocTorq, Borin & Strokin, etc...
My truck didnt even want to idle correctly when I added a K&N FIPK, so as bad as I want to do cam and headers, I must say that I am a little skeptical of the side effects. But you guys testify that the idle is satisfactory with cam and headers?
Thanks for the great info
Eric
__________________
1990 F250 EC 460/E40D/3.55s, 3.5" straight pipe: NA=220 rwhp, 360 rwtq; 50shot=264rwhp, 415rwtq; best 1/8 mile 9.9 w/2.2 60ft
  #34 (permalink)
Old 10-02-2006, 10:45 PM
justshootme84 is starting off with a positive reputation.
I also found this thread had lots of useful info. A question? I'm converting my 88 460 EFI to carb with a special adapter on the stock intake. I am using the stock cam for now, but wonder what would be a good replacement? JSM84
__________________
84 Bronco XLT, 460, C-6, Dana60, Sterling 10.25", 36" GYR RT-II's, Herculiner, S&W 10-pt cage kit, PRP racing seats, Skyler softtop, "Shaker"
88 Bronco Custom, 302 EFI, C-6
86 Bronco Custom, 300 I6, NP-435
78 Bronco Custom, 351M, NP435, 38" TSL's
79 F-150 4WD, 351M, C-6, 35" MT's
  #35 (permalink)
Old 04-19-2008, 01:52 AM
dutchlincoln79 is starting off with a positive reputation.
ok, in order to keep this thread alive, shall we go on with pistons?
I purchased a revised '91 460EFI which had some small upgrades, of one being the keith black KB138 pistons. They have a 22cc dish in them, and should get the stock 8.4cr up a bit to 8.8cr.
I don't know why this piston was chosen, but i think about replacing them for much higher CR. Do the people here have some advices? Only piston i could find, was the domed KB401, with a -11cc dome on it... Should bump the CR up to 11. Can't find them anywhere however, and i'm curious if i can use ther rings from the 138 that are currently in... Engine has never ran yet...
Any info is very welcome.
  #36 (permalink)
Old 04-20-2008, 08:06 AM
hotrodmerc's Avatar
hotrodmerc is starting off with a positive reputation.
I put a ford Cobra Jet cam in mine. 282 dur/510 lift. It has a slight lope at idle. It has great torque and man does it pull hard. The RV type cams are a great improvement.
__________________
Tony
  #37 (permalink)
Old 05-10-2008, 02:10 AM
460ton is starting off with a positive reputation.
I have a 93 that I just rebuilt. Put the comp efi cam in and the headman headers on. Just have to put the rebuilt trans in. Would a adjustable fuel regulator be a good upgrade?
  #38 (permalink)
Old 05-10-2008, 05:21 AM
hotrodmerc's Avatar
IMO it's not really necessary with the batch fire injection.
__________________
Tony
  #39 (permalink)
Old 05-12-2008, 11:25 AM
Smile
Quote:
I think that would be a good idea. I realize that this is ideally taken care of with the computer, but from the data I have read, the adjustable FPR allows for some fine tuning and therefore possibly getting those extra horses that are always being looked for.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
