Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-13-2004, 12:49 AM
hanajack is starting off with a positive reputation.
Gear Pop-0ut
I have a '78 E-250, which I bought new. It has the 300 6-cyl., and a manual 3-speed transmission with shift on the column. It has 71,000 miles on it.
I've had first gear pop-out [only when decelerating or going down a hill] for some time and have lived with it.
I now have second gear pop-out which occurs at the time the shift is made and the accelerator is pressed - in other words, when I'm ready to go in second.
I have checked and re-set the shift linkage countless times using the 3/16" pin for alignment. I have also tried many out-of-alignment settings to see if I might see a change. No luck. All bolts to engine, clutch housing and trans are tight.
I know this van is an unusual option package but they are out there. Does anyone have a clue as to what is causing this and/or have a possible fix - short of rebuilding the trans.
Thanks, hanajack
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-13-2004, 03:35 AM
c96drumm's Avatar
c96drumm is starting off with a positive reputation.
I had an 84 with the 4 sp. manual (3+OD), had same problem. It was worn shift forks. Replaced them and it was fine.
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
