Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-12-2004, 09:36 PM
SamD is starting off with a positive reputation.
6 volt booster?
A neighbor was telling me about a way to put on some type of booster or something like that to just juice up the starter to 12 volts during ignition to give that extra umph to start, but then continue to run on the 6 volt system. Does anyone out there know what the heck this is about and any more information about it, is it possible, is it practical, is it worth doing? This is my 1941 truck with a positive ground. Thanks ---Sam
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-15-2004, 08:27 AM
GreatNorthWoods is starting off with a positive reputation.
Re: 6 volt booster?
Sam,
I haven't seen one in years, but at one time there was a 12 volt battery available with three posts. From the center post to the outside negative post was 6 volts and between the two outside posts was 12 volts. It was used a lot for 12 volt conversions from 6 volts, but you could keep all the 6 volt accessories by just coming off the center post to ground. I don't know that they are made anymore, but if you could find one of these batteries, you might be able to wire up the starter only for 12 volts. The only problem is, you would have to convert your charging system to 12 volts. Probably a better solution would be to just convert the whole system to 12 volts and keep your 6 volt starter.
__________________
Vern
48 F-3 Pickup
  #3 (permalink)
Old 02-17-2004, 07:27 PM
56f600 is starting off with a positive reputation.
I just found in my shop a power inverter/booster. I bought it years ago to run a radio in my positive ground MG. It turns positive grd. to negative grd. and takes 6 volt positive or negative grd. to 12 volt negative grd. Unfortunately, it has a max output of three amps. Not enough for a starter. I have never seen a booster that would be big enough for starter.
__________________
Mark
1956 F600
flatbed dump
  #4 (permalink)
Old 02-18-2004, 06:03 AM
Thanks for the replies, We live around a lot of farms and my neighbor said some man that lives around here does the booster thing to 6 volt tractors, I don't know, just wondered if anyone out there had heard of such a thing.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
