ididit column and drop
on
hi guys...
got my shiny new Ididit column and column drop... problem #1 ... the column drop is an extremely tight fit on the column and I'm not forcing it on to scratch up my column... anyone else have this problem ...??? what did you do ??
problem #2 this is a one piece polished drop... and with the above mentioned tight fit.. there ain't now way it's gonna slide up over the GM connector and wiring/grommet in the column.. one option I see is cutting the drop across the diameter of the hole... then mill it out to make up for the material lost in the kerf... but why am I having to do this ??? any suggestions ??
I'm calling ididit tomorrow and see what their column gurus have to say... but I'm open for suggestions...
thanks
john
thanks
john
What a pain in the ****. Doubt I'll be of assistance here because I have a Flaming River column and a Billet Specialties swivel drop. My drop hits the column almost directly beneath the dash, about 2 inches below the column shifter bowl. My wiring exits about 8 inches below the mount location near the brake pedal. Where do your wires exit the column on Ididit? Tell me your wiring doesn't exit out the shifter bowl like a stock GM column? If it does, you're going to have to do your machining idea for an attractive install. You could go around it for the moment while you regroup though. You sound frustrated. Been there, keep your cool, a machinist can cure anything.
As far as the tight fit, I think they want a slight interference fit. A drum sander in your drill should cure that if you're close. But your machinist might have a better plan. I taped my painted column while I jacked around with drop location.
John-
I bought an IDIDIT column and Billet Specialties drop but the drop was a split type with inset allen head screws in the bottom half. Are you sure yours is not already split? I don't know how they would expect you to put everything together with a solid piece. If yours is not split, then I suggest you return it and purchase a split one from Billet Specialties or another source. Best of luck.
Larry
Larry
on
my wife was right
my wife was right...and as she so often comments.... I'm an idiot... I called Ididit this am.. and found out this is a split ring drop... but the finish was so smooth you absolutely couldn't see a break till you loosened the set screws... I thought the set screws were long and applied pressure to the hinge part to hold it in position... I am so stupid...
it was a perfectly smooth polished finish... they must tighten it down then polish it out so the line disappears... it's amazing... two other people looked at it (one is a good machinist)and couldn't see it either.. as soon as I told Hank at Ididit the problem... he said loosen the screws and you'll see it... and it was also nice of him to say "You're not the first one to call back with this problem... in fact, you're not the first one today !!" soothed my bruised eqo somwhat...
so all of you that thought John actually knew something.... well please contact my wife... she knew all along...
thanks for your help anyway..
later
j ( cool... AND stupid)
later
You're right John. Some of the suppliers do such a good job of polishing that the line completely dissappears. I saw one last year in the display case at Sacramento Vintage Ford. I asked the guy behind the counter how anybody could install it as it looked like a solid piece of metal with a hole in it. He said he got that all the time and that it was actually a split unit. So, happy installing. John
