Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-11-2004, 08:27 PM
matloik is starting off with a positive reputation.
Question Windsurfing / camping van conversion
Being the excited new owner of a 2001 E350 (cargo), I'm about to embark on the journey of doing a van conversion on it. It will become my windsurfing/camping RV. I will be having a conversion outfit put in a couple of windows (it has no side windows at present); do the floor, walls and ceiling; put in some lighting; install PDLs; and a 50" wide sofabed. The floor will be black, low-pile marine carpet; the walls will be 1/2" closed cell foam + 1/8" wood + medium gray foss upholstery fabric. I will be doing some pre-wiring, and later adding aux power, cabinets, table, sound system, computer system and DVD ... and even later, propane a kitchen unit, and furnace. Anyone else on this forum do anything remotely similar? One question I have is whether I should stuff or inject some insulation into the wall and door crevices for added soundproofing and insulation? Any other recommendations also appreciated.
-mat
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-14-2004, 01:34 AM
Alan P is starting off with a positive reputation.
I've been looking at insulations like this one:
http://www.superhvac.com/astrofoil/help/
that have foil faces on 2 sides. There are a bunch of different
types of core materials. HVAC supply stores might have something cheap in bulk rolls.
http://www.quietride.com/article.html
has some pics of this type material.
1/8" sounds a little thin for plywood but might be OK if you found some high quality panels.
Alan P
__________________
1971 F250 Crewcab
1991 E350 351w/e4OD
1995 F150 300 I6/5speed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
