Fluffy white powder under truck
white powder
Depends on what neiborhood you live in. Could be a dope fiend sleeping under your truck at night and spilling some.. LOL , I am sorry, I could not resist...
I have never heard of it. Might well be the battery leaking off.
www.texashorse.net
www.texashorse.net
Well,
I looked into the battery leakage therory and can't seem to find any signs of that being the culprit.
Maybe Texashorse is right ...
some dope fiend use my truck as a smack shelter! lol
Could this be from an exhaust leakage?
I park my truck in a carport and let it idle in the mornings to warm up.
I just finished sweeping the area and will continue to keep an eye on it.
If anyone has any other ideas would be greatly appriciated.
'Dope Fiend ... ya right!'
Snow in Vancouver Dave? Ya right! That's a funny one. What is it anyway? never seen it in my life.
All that we get here is what the west (wet) coasters call ...
Liquid Sunshine!
Yup, rain rain rain rain rain rain!
We usually get one dump a year and it only lasts a week at the most.
I thought that it was road salt at first but I did a complete pressure wash of the undercaraige and it has popped up since that. I'm gonna keep my eye on it for the next few weeks and see if it pops up again.
Thanx guys for your help.
Liquid Sunshine!
I havn't a clue. HEY, I just found a new add in our local paper here in Wichita Falls, Texas. A guy is selling reman long blocks for 7.3 diesels for 2695. with delivery available. Sounds good to me...
www.texashorse.net
www.texashorse.net
I'd have to say I don't have a clue for sure either. The battery is the only think I can think of. Once I saw the other end of the battery cable to the same white power thing (on an old tractor). I don't understand how or why but if it happened to you then the battery theory might be right, but occuring down by the starter or one of the other wires.
Again I don't know how that happens but it did on that tractor so it must be possible.
I'll be intrested to know how this one turns out.
The white powder corrosion is the result of hydrogen sulfide gas being released from your battery while charging. It condenses on the metal supports, battery posts and wires. It can travel inside the insulation on the wire to cause corrosion in places you can not see normally, till it breaks open.
Check out rotating parts.
Do you have a plastic fan or a metal one?
That black plastic fan shroud will shave off white if the fan is doing a very light rub on it.
Look at your fan clutch for traces of the powder.
Look at the vacuum pump area as well as the alternator.
Check the water pump shaft for play.
Could be a bearing or bushing is letting something rub something it is not supposed to.
If you said it was black I would look at the exhaust.
White is a little harder to come up with on a diesel, everything is black on and in them.
If it were coming from the engine compartment there should be traces of it on top of the springs or differential housing.
Maybe texashorse was right, the NCUC is laying out lines on your truck hood at night. (NCUC = Neighborhood Cocaine Users Club)
coilsprungf350
12-18-2014 01:52 PM
