Recently purchased a '99 F-350 w/ 7.3L diesel, 78K on engine and used 1 quart during first 1100 miles I've owned it (3 weeks mostly highway) using Rotella 10W-30. Any ideas why or things I should be concerned about or have looked at? Thanks
If you open your fuel filter housing and check the color of the fuel it may give you a clue. Injector O Ring failure will cause motor oil to get in the fuel, giving the fuel in with your filter a dark color rather than the yellowish green clear fuel you should find.
