Another Predator Question
Does the code scanner pick up a fault if any of the ABS wheel sensors go bad? I have one front sensor that has crapped out but the scanner did not show a fault. I did a pin point test as shown in the manual and the right sensor is bad. I would have thought that a code would have shown up for this component. Any thoughts?
