1950 F-1 - Positive or Negative ground?
Old 02-10-2004, 11:01 PM
harleyclassic's Avatar
harleyclassic
harleyclassic is offline
I have a 50 F-1 that had been converted to 12 volt with an alternator. I know these trucks started out with a positive ground but would that change with a modification to the charging system? It's been over 5 years since I had a battery in this truck and can't remember how it was set up. Just want to be sure before putting juice to it.
Thanks.
Old 02-11-2004, 12:04 AM
mtflat's Avatar
mtflat
mtflat is offline
It could be 12 V without being changed to neg grnd.
Look at your coil. What post goes to the distributor? If you are negative ground the (-) post will lead to the dizzy.
If pos grnd it will be the (+) post.
crossy
07-21-2017 11:02 PM
jtharvey
16
01-05-2017 02:24 AM
3twinridges
20
08-19-2016 06:49 PM
Nathan Kiolbassa
04-29-2016 02:49 PM
df85732
11-06-2015 09:12 AM
Quick Reply: 1950 F-1 - Positive or Negative ground?
