Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-10-2004, 09:02 PM
shel shel is offline
Garage is empty, add now
shel is starting off with a positive reputation.
4 banger won't start
Hi all, my daughter has an '88 mustang with the 4 cyl. in it. The battery is fully charged, but sometimes it just clicks once and that's it. I had this same problem years ago on an '84 mustang ghia with a 255ci. in it. Seems to me that it was the voltage regulator mounted on the fender well that was the problem then, but can't remember for sure. Any clues?
Thanks. shel
  #2 (permalink)
Old 02-10-2004, 09:19 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Before you get all wound up changing parts, make sure that the battery is fully charged. Next, use booster cables, or something suitable to substitute the existing battery leads. The problem could be as simple as that.
A rusted connection at the starter could also be the culprit. If the starter on that car has a solenoid on it, take a screwdriver and jump the battery lead at the solenoid to the power lead for the electric motor. If it is the non-solenoid type,you will need someone to be holding the key in the start position while you BRIEFLY short out the lead at the starter. This will NOT make the bendix kick out on the first type of starter, but WILL on the second. What this does is uses max battery power to "burn" through the rust.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
Tags
1979, cyl, fire, mustang, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
