I am looking at 1984 f250 to purchase. The axle code is 31 per manufacturer's sticker on driver's door jam. Could someone please tell me the ratio for this axle. Thanks.
Unfortionately, axle code 31 is not listed. I think 31 is a Dana 61 3.07. 33 is (at least in 85) a Sterling 3.54, and 35 is a Sterling 4.10.
Best way to find out is look at the tag or the BOM on the diff, or jack it up and count the revolutions.
__________________ http://mav.wastegate.net
'00 in the drive, '85 F250 that runs, '84 F150 in the weeds, minus 1 '85 F150- I finally got rid of some junk..
Yes. That list for some reason is only a partial list mostly from 1990 and up. My 86 F-150 has a code of H6 which is a 3.50:1 limited slip. It is also not shown on that list.
#31 is a Dana 6250# Capacity axle with a 3.07 ratio.
This is out of the 1985 Ford truck shop manual.
The only way to tell what model it is, is to retrieve the #'s off the tag affixed to the rear cover.
I'm am pretty sure that 8lugs is right. Sterling axles didn't have gears lower than 3.54s, so they carried over the dana 61 model. which had a different carrier for 3.07 gears.
I don't think ford changed the codes in '85, they just came up with different codes for the new sterling axles.
I just bought an '86. The owner's manual has the de-coder for the rear located near the trailer towing section. I don't have my book with me, but if you need info, reply and i'll bring it tomorrow
If you could post the contents that would be great to post on a site of codes.
Its nice to have the info available. Btw, have any one of you seen the code "H9B" for differental code? It was on a 94. It was factory track-lok front and rear diff. weird to see that, but nice truck
