Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2004, 10:23 PM
biglee is starting off with a positive reputation.
1945-46 ford 1/2 ton pickup rear differential,how to figure the ratio ?
Hi all,
I just put a 1945 ford 1/2 ton pickup rear differential,open banjo,on ebay.
But I don't know how to figure out the gear ratio.
Can anybody help me out here. I'm getting swamped with ratio questions.
Is there a standard ratio that they put in the 1945-6 ford pickups back then ?
Thanks,
Lee
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-10-2004, 03:53 AM
old farmer is starting off with a positive reputation.
biglee, try this. With the axle off the ground, mark the input shaft and the wheel that turns when the input is turned. Turn the input and count how many turns it takes to get one turn of the wheel. Or you could take the cover off and count the number of teeth on the gears.
  #3 (permalink)
Old 02-10-2004, 11:05 AM
46fordtruck's Avatar
46fordtruck has a good reputation on FTE.46fordtruck has a good reputation on FTE.
Farmer is right about the turning thing, but don't disasemble the rear to get the ratio, since that would require removing the axle tubes, since these rears don't have covers. They did have a standard ratio, usually a 3.78, other ratios were optional.
__________________
Gary-
Down to only one, a 1946 1/2 ton
Collector of anything related to 42-47 Ford Trucks
  #4 (permalink)
Old 02-10-2004, 03:23 PM
Hi all,
thanks for the help.
I turned the input shaft 2 complete revalutions to 1 revalution of the drum+2".
What ratio is this ?
Thanks,
Lee
  #5 (permalink)
Old 02-15-2004, 08:24 AM
Biglee: Forgot to mention that I think you have to multiply by 2. So you would be 4/1. Likely a 4.11/1 ratio. Sounds like a truck type ratio!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
