Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2004, 07:46 PM
bri_877 is starting off with a positive reputation.
77 f250 power steering conversion
i have an f 250 with manual steering that i would like to convert to power. i already have a pump mounted and working and now need to know what gear unit to use and how to install it correctly. anyone? thanks... bri
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-09-2004, 07:51 PM
Jimbare's Avatar
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
if it is 2 wheel drive, 1/2-1 ton gearbox will fit. you will probably have to change the steering column also. most power boxes are longer than the manuals.
if you have a 4x4, and it has the power assist cylinder, you will have to get the box and shaft out of a late 77-79 4x4 truck. you will also have to have the tierods and draglink to make the swap.
__________________
jim
underated and overworked.
  #3 (permalink)
Old 02-09-2004, 09:29 PM
sorry for the lack of info. it is a 4x4 with the original manual steering box currently installed. my biggest issue seems to be what unit to use and how to mount it (will it bolt right on?) while keeping the proper angles in the steering linkages. thanks
  #4 (permalink)
Old 02-09-2004, 11:19 PM
Jimbare's Avatar
yep it will bolt right on. just be sure to get the tie rods from wheel to wheel.
__________________
jim
  #5 (permalink)
Old 02-14-2004, 10:16 PM
460EFIhighboy is starting off with a positive reputation.
A guy on ebay sells kits. I bought one about a year ago and it still works great.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
