Its Ball Joint Time
Mine are shot as well. Just failed state inspection. How tough are they do do yourself? I've done most of the work on my vehicles for over 30 years but never had to do ball joints. I picked up a Haynes manual for the Superduty and it recommends that the dealer do this work. The dealer wants $750 for both sides, parts and labor.
Where are the Moogs available? By the way, my truck is a '99 F-250 Super cab.
Thanks for the info.
Its not really hard but you will need to learn and do it properly and aquire some new tools or rent them...
Look here and see what you think....https://www.ford-trucks.com/contents...20Installation
Car quest sells moog.
You can get Moog ball joint at CarQuest for total of $100 for one side upper and lower. I'm only doing the driver side. Parts needed from Ford Stealership are as follows: F81Z-3254-CB (oil seal) for $32.22, F81Z-4A322-AA (o-ring) for $4.79, and F81Z-1S175-HCA ( retain assy) for $17.92. So for $155 you can do one side if you have the tools. Hope this helps someone....
RedCrewCab4x4
RedCrewCab4x4
Deersniper,
I figure better safe than sorry, took the stealership 2 days to get the special order parts. My truck is 5 1/2 years old and may need this soon anyway, as instructions call for at Dieselstop.com. Ended up paying $131 for everything due to CarQuest discounting the parts I got... Job starts Friday.
Semper Fi, it's a Marine thing
RedCrewCab4x4
RedCrewCab4x4
I'd to both upper and lower at the same time, that way you only do it once.
On the none 4x4's it take us about an hour to do upper and lower per side. I haven't done a 4x4 yet. But it can't be too hard. When you press out sometimes you may have to hit it with a hammer as someone is using an impact on the press.
We have one simular to this one www.northerntool.com Item# 124794
DeerSniper
10-16-2003 08:25 PM
DeerSniper
08-26-2003 06:08 PM
