Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2004, 02:35 AM
steetsel is starting off with a positive reputation.
Rear brakes on a '42
I recently pulled my brake system apart on my '42 Ford 1 1/2 ton. I have a splitter on my rear axle that connects the flexible hose (which connects to the steel line coming from the master cylinder) to the lines going to the rear wheels. One side of my splitter is stripped out. I have taken it to many parts places and have had no luck in getting a new one. I can't even get a straight answer out of anyone as to why it is such a hard part to come by - i.e. are splitters uncommon, is it the size, what is it?
The threads going out to the rear wheels is a different thread than the incoming line I have found out.
Where can I get this part, or what can I do to get parts and make it all work?
Also, does anyone know how the e-brake is supposed to work on a '42 Ford 1 1/2 ton? No lines to the rear wheels and no band around the driveshaft? Maybe they just threw an anchor!
Thanks!
Scott
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2004, 08:44 PM
41Clay's Avatar
41Clay is starting off with a positive reputation.
In my home town Ac Delco carries them and many other. The sizes shouldn't be that hard to get. Some places have rings of those nut and bolt things that tells you what sized of threads you have to make searching easier. Ac has adapters here that can be used to mat different size threads.
About the e-brakes , the only place I've seen them on the really big trucks is right on the tail of the tranny with the lever bolted right onto the side. So maybe someone swapped the tranny with no regauard to the e-brake.
Good luck!
Clayton
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
