What is a swing bearing? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-29-2002, 06:50 PM
Jared95Z Jared95Z is offline
Jared95Z is starting off with a positive reputation.
What the topic says. On a 01 F350.
Old 04-03-2002, 10:11 AM
NoMo's Avatar
NoMo NoMo is offline
NoMo is gaining momentum as a positive member of FTE.
So nobody else knows either?
Old 04-03-2002, 11:18 AM
spartamouse1 spartamouse1 is offline
spartamouse1 is starting off with a positive reputation.
what does it have to do with or where is it located? never heard of a swing brg but sometimes people use a slang term instead of the "propper" ford term.
Old 04-03-2002, 01:27 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
My motorhome has a carrier bearing.which is a bearing mounted
on the cross member between the 2 piece drive shaft.
never heard it called a swing bearing though
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old 04-03-2002, 02:01 PM
NoMo's Avatar
I've never heard of anything on a pickup called a swing bearing either. So, I searched the 'net for "swing bearing" and found a lot of hits- but none were automobile/truck related. Mostly crane, dozer, front-end loaders, and a few motorcycle/atv sites.
Old 04-04-2002, 09:23 AM
Mike Earls Mike Earls is offline
Mike Earls is starting off with a positive reputation.
Maybe I'm just older or maybe it's locale (SE Texas). I started in the auto parts business back in the 60's.
Swing bearing was commonly used to refer to the driveshaft support bearing or carrier bearing. Carrier bearing may be a misnomer since carrier bearing normally refers to the side bearings in a differential.
Mike
Old 04-04-2002, 10:33 AM
Waxy's Avatar
Waxy Waxy is offline
Waxy is starting off with a positive reputation.
If the bearing you're referring to is the the bearing that supports a two piece drive shaft, here in Saskatchewan, Canada, we refer to it as a center bearing. I used to have to change these things on my '89 F250HD SC LB 4X4 like oil. Any mud + water and it would be shot, got really annoying at $50-60 a pop.
Never heard of it referred to as a swing bearing, so I may be way off base.
Waxy
Old 04-04-2002, 01:38 PM
FortyFords's Avatar
Hey waxy ! were you using oem or aftermarket replacements!
reason i ask is the spicer aftermarkets are sealed an have a grease fitting on them now!
Yea ! carrier or center bearings is problably what this guy is talking about
Later
Rich
not with rocks
Old 04-04-2002, 03:14 PM
Waxy's Avatar
I started out buying the cheapies, eventually I started buying the Spicers and they'd last about twice as long. Fortunately that's not my headache anymore!
Waxy
Old 04-04-2002, 03:45 PM
Munkey's Avatar
Munkey Munkey is offline
Munkey is gaining momentum as a positive member of FTE.
What is an OASIS report? superhooperduty 1999 to 2016 Super Duty 2 03-03-2014 11:05 PM
Whats the best Antifreeze? sparkkky 2004 - 2008 F150 1 08-21-2011 04:02 PM
what's this code jwhitetail Computer Chips & Tuners 5 03-24-2008 08:43 PM
What is the 7700 pkg? Multipierce 1997 - 2003 F150 11 10-12-2003 04:02 PM
What's the right thermostat? jowilker 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-09-2002 10:21 AM
Tags
03, 250, bearing, change, f150, f350, swing, term, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
