390 help
Yes, there is gasket that should be readily available at your local parts store. Used with a little gasket sealer, you should have no problems.
I think there were a couple of different FE thermostat housings. It may just be a difference in the inner diamter where the T-Stat sits. But, take yours with you and look at the gasket for a match.
You can look at one for just about and size and year of the FE engines (360,390,428 among others).
As for the steps: drain the radiator a couple of quarts so the fluid level is below the T-Stat housing. Remove the hose from the housing, and remove the 2 bolts from the housing. It should come off with a slight tap of a mallet. Clean off the old gasket and replace. It shouold be straight forward :-) How many times have I said that to be proven wrong.
Good luck.
Good luck.
The housing has a lip cut in for the t-stat to sit in. Make sure the t-stat does not slip out of this lip when tightening down the housing - it will leak. Then when you tighten the bolts to stop the leak, you will crack the housing and have to get another.
Another tip - do not over tighten the bolts - just snug is good.
Do not ask how I know this....
Today I learned the rubber band trick. After two failed attempts with a slipping t-stat, a very good shade tree mechanic showed me the trick.
Take a rubber band, the t-stat, a popcicle stick and the housing.
Run the RB through the hose end of the housing, feed the RB through the metal wire on t-stat and back through the housing.
You now have the two ends of the rubber band out the hose end of housing. Take a popcicle stick loop each end of the RB. Now the t-stat is good and tight against the seat in the housing. It can not slip.
Put on the gasket and sealer and bolt up the housing. Now hold ends of RB, take out the popicle sticks. Pull out the RB and you have an installed t-stat.
1999XLT
1997-2006 Expedition & Navigator
32
07-25-2008 04:09 PM
Farmers Ford
01-21-2003 10:20 PM
