Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-08-2004, 10:14 AM
Seanny is starting off with a positive reputation.
Leaking Club Wagon
Since i bought this van i have had a overheating and antifreeze leak problem. I have changed 3 water pumps radiator and 2 thermostats. I took the thermostat out and the van did not leak or overheat all summer i recently put back in the thermostat now its starting to leak at the water pump. Some one please help.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-09-2004, 02:43 AM
c96drumm's Avatar
c96drumm is starting off with a positive reputation.
You're not letting the thermostat slip down when you install it, are you? I've had that happen, it keeps the housing from sealing and it leaks. Where on the water pump is it leaking? Shaft, weep hole or mounting flange?
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
  #3 (permalink)
Old 02-09-2004, 05:00 AM
i am not really sure where it is leaking i have also had to replace the gaskets on the water pump mount 2 times there is no flow of the antifreeze once it gets hot so i do not know what the deal is. maybe i should get a lower temperature thermostat becuase it looks like it is not opening up when the antifreeze is hot. Also the the rear heater blows cold air even thought the front vents blow hot air.
  #4 (permalink)
Old 02-10-2004, 01:40 AM
c96drumm's Avatar
Thermostat's not in backwards, is it? Don't know why you'd have so much trouble with the pump gaskets. As for the rear heater, if yours is like my 89, there is a vacuum operated heater control valve in the heater hose going back there. Might have a look at that, and make sure the rear heater core isn't plugged. What year is your van, what engine, etc.?
__________________
89 E-150 302
96 Explorer 302 AWD
00 Windstar 3.8
  #5 (permalink)
Old 02-12-2004, 09:46 PM
pops_91710's Avatar
pops_91710 is starting off with a positive reputation.
I am betting on an upside down T-stat!
__________________
2003 Ford F-250 S/D XLT SC, 4X4, 6.8 V10 Triton, 4.30 axles w/Gear Vendors overdrive. Firestone 265/75R16 Transforce HT. Pullrite 16k Super 5th hitch/2006 Cardinal 30LE WB
Mike Harrington
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
