Camshaft Sensor/Synchronizer Replacement
Old 05-25-2004, 01:14 AM
nerdwannabe's Avatar
nerdwannabe
nerdwannabe is offline
Originally Posted by Ranger3L
menardrs:
...................... I couldn't find the "special tool" so I just replaced the syncronizer in the exact position I found it. Works great.
Good thing that it worked. To my knowledge, OTC is the only big company making CMP tool for Ford (authorized by Ford). A complete 7 piece alignment tool cost about $350. You are unlikely to find it or rent it in parts stores.
Another alternative I found its http://thetoolnetwork.com/cam_syncronizer_set_ford.html appeared made by 3rd party.
  #32
Old 06-22-2004, 01:37 PM
Ricky Thomas's Avatar
Ricky Thomas
Ricky Thomas is offline
Exclamation Needing help finding special tool
Can someone please tell me where I can find the special tool for positioning the cmp, 303-529. I live in Kansas City and apparently no one has ever needed this tool before in my area. I've tried Avanced, Oriely's, Napa, every Ford dealer in town. I can find it on the net but i'm needing quicker than they can get it to me.
  #33
Old 07-18-2004, 09:31 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
How to Line Up Synchronizer Without Special Tool
I ran across this "how to" regarding how to line up Ford cam synchronizers without using the special tool:
Today, it seems you can't compete even the most routine job - such as replacing a timing belt - without these new tools. One question our hotline callers often ask is how to align a camshaft position sensor synchronizer without Ford's special tool.
Here I am using a 1995-1998 3.8L Ford Windstar as an example. Usually the problem starts after engine work has been done. Maybe the timing cover has been removed or the engine was replaced. Either situation requires the synchronizer to be installed and timed to the engine. The service manual states that a "special tool" is required to index the vane inside the synchronizer to the housing. As you read through the procedure, you may be thinking, "I don't have that tool - now what?"
Good news! You can line up the synchronizer without a special tool and without a lot of extra time. Here's how:
1) Bring the engine up to top dead center (TDC) of the compression stroke for cylinder No. 1.
2) The engine needs to be positioned at 26 degrees after TDC. There will often be a large groove machined into the balancer at this point. If not, mark the balancer by measuring from TDC to 26 degrees before TDC. Take that measurement and make your own mark at 26 degrees after TDC.
3) Drop in the synchronizer so that the leading edge of the vane is close to the center of the opening in the housing (this is directly below the actual sensing part of the cam sensor).
4) Leaving the synchronizer loose, install the cam sensor and connect a voltmeter from the ground to the dark blue/orange wire with the sensor plugged in.
5) With the key on, the voltmeter should read either "0 volts" or "battery voltage."
6) Turn the synchronizer back and forth to find the point where the voltage is just switching from "0 volts" to "battery voltage."
7) Once you find that point, tighten down the hold-down bolt.
This same procedure can be used on most OBD-II Ford products with Hall-effect type cam sensors. Source
  #34
Old 08-09-2004, 05:04 PM
animal_friendly's Avatar
animal_friendly
animal_friendly is offline
Rockledge,
Thank you for your posts on this CMP/synchronizer problem. I was able to fix this problem and get that engine code off my '95 Ranger (after driving 100 miles) because of this thread and your responses. It makes me proud to own a Ford p/u!
PS. I couldn't find that synchronizer alignment tool, but was able to bend an aluminum can tab and wedge it in the new one to keep it from moving.
Cheers!
  #35
Old 08-13-2004, 05:21 AM
Rockledge's Avatar
Rockledge
Glad to hear it worked out! I accept your thanks on behalf of everyone who has contributed to this very helpful and informative thread...
  #36
Old 08-27-2004, 11:02 PM
inkpap's Avatar
inkpap
inkpap is offline
Question Inkpap
I have a trouble code PO340 and the dash light is on. With all the help on this site I was able to find the darn sensor. I have a ticking noise that's coming from it. If I put my finger on the top of it I can feel the vibration. This is on a 1996 Ford taurus 3.0 with 58,000 miles. Can just the sensor make this noise or am I looking at replacing other things? I bought just the sensor tonight and the only thing I can see that might do this is if the metal tab in the middle of the sensor might be loose......I'm hoping!! I'm going to take the old sensor off tomorrow. Any Ideas? Money is tight right now so this is something I'm going to have to tackle myself.
Thanks for any info !!!!
  #37
Old 08-28-2004, 11:12 AM
Rockledge's Avatar
Rockledge
Welcome to FTE!
Usually if it's making noise like that, the whole synchronizer assembly needs to be replaced. But trying out the new sensor is easy enough, so why not give it a shot first?
  #38
Old 08-29-2004, 06:18 AM
inkpap's Avatar
inkpap
inkpap is offline
Originally Posted by Rockledge
Welcome to FTE!
Oh well it was worth a try. As luck would have it I had to buy the whole assembly from Ford. Now that I have all the new parts in hand I can't find that "special tool". I've tried several places around here. Let me run this one by you. Can't I just mark the ends of the "C" from the old assembly on the engine block and also mark where the sensor was? (this is a 1996 Taurus 3.0 Vulcan) I've found this site to be a great help. I asked the guy at Ford for advice and he said " I just sell parts". NAPA said don't mark anything.....just drop the new one in. I did buy a Haynes Repair Manual and it's a big help. They show the "right" way to do it, but I have a feeling there must be another right way also.
Thanks again!
  #39
Old 08-29-2004, 08:45 AM
Rockledge's Avatar
Rockledge
I've never changed the assembly myself so I wouldn't know for sure. But I've heard about people simply marking things and being able to get the job done without the special tool. I myself would be inclined to follow the instructions that have been posted in this thread, as they are proven methods.
  #40
Old 08-29-2004, 08:44 PM
inkpap's Avatar
inkpap
inkpap is offline
Smile Rockledge
Rockledge,
I installed the sensor and assembly today without the "special tool". I marked things real well before removing the old one so I'd be sure to get the new one in the same exact place. It worked and my car runs great! It took me 1 hour 45 minutes to complete the job. The sensor cost $37. and the assembly $142. I really like Fords but the design of the sensor is a joke. The metal magnet inside the sensor fell off damaging the assembly. The "c" looked like a "d", but not bad enough that I couldn't figure out where one of the ends were before it got twisted. I know this is a "truck site" but I do own a motorhome on a Ford E350 (V-10)....I hope this matters....lol.
Thanks so much for your help and all the other people who have posted info and repair ideas about this problem. This is a great place and believe me I've looked at a bunch of others that arn't worth a darn. Lot's of good people here!
Thanks Again !!!!
  #41
Old 08-29-2004, 09:46 PM
Rockledge's Avatar
Rockledge
Rockledge,
Thanks Again !!!!
Hey that's great! Helpful feedback, too. It's good to know that the repair is doable (at least in some cases) without the special tool by marking things carefully.
The manner in which your synchronizer shaft was destroyed is common, so I'd have to agree with you on the design.
And BTW, yes the 3.0L "vulcan" engine in your Taurus is the same one that's in the Ranger.
  #42
Old 09-28-2004, 10:23 AM
RangerRuss's Avatar
RangerRuss
RangerRuss is offline
Replaced my sensor this week. Here's what I found:
Napa - Echlin/Niehoff part FF2104 - entire unit shaft and all - $245
Just the electronic module: 2 screws on top to remove it .
Motorcraft DY 908 - $49
Standard PC14 - $34.01
Hope this helps.
Russ
  #43
Old 10-10-2004, 12:30 AM
crandell85's Avatar
crandell85
crandell85 is offline
7th Gear
CMP Sensor_Synchronizer replacement_walkthrough
Might help:
http://autorepair.about.com/library/faqs/bl025h.htm
  #44
Old 01-10-2005, 07:25 PM
Rockledge's Avatar
Rockledge
Wink My Turn for DTC P0340
Well, it happened. The CEL came on my Taurus yesterday, so I pulled the codes and guess what came up? P0340 - Camshaft Position (CMP) Sensor Circuit Malfunction.
When I saw the code on the scanner I immediately thought of this thread and the experiences of the people who have posted to it regarding their own CMP issues. I pretty much knew I was looking at replacing the cam sensor at least, and maybe even the synchronizer/shaft, as well.
Getting at the sensor & synchronizer/shaft on the Taurus requires removing the upper intake on account of the throttle body assembly being located at the rear of the engine - hence the linkage sits directly on top of the CMP sensor (remember the Taurus engine is mounted transversely). I’m not sure if this same requirement exists for the Ranger vulcan, with the TB assembly being in the the front of the engine.
My Taurus was filthy with dirt and salt from a recent winter storm, so before getting going on the repair I drove it over to the local carwash in order to clean it off. When I got back, I noticed a slight squeaking sound was coming from the engine in the area of the cam sensor. The sound wasn't quite as high-pitched as a belt squeal or pulley chirp, it had more of a “scratching” tone to it, however I can understand how the noises might be confused. In any case, this development made me more concerned about a possible synchronizer/shaft problem in addition to the bad sensor.
When I finally dove in, pulled the upper intake off and removed the cam sensor, I was happy to discover that the synchronizer/shaft assembly, including the Hall-Effect vane switch, was still intact and did not look bent or broken in any way [in the pic below, the red arrow points to the intact vane].
However, I did find that the magnet from the sensor had broken completely off and was lying on the base of the vane switch. [The pic below shows the underside of a good CMP sensor, with the magnetic tab encircled in red].
I attribute the slight squeaking/scratching noise I heard to the metal-to-metal contact of the broken magnet and the base of the vane switch. Because of this experience, it is easy for me to understand how a loose, broken magnet "tab" could start dancing around and get jammed up in the spinning vane switch, bending and/or breaking it.
Long story short, I got off with just replacing the sensor. Cost me $32.00 for the sensor, and along with the $6 I paid for a new Fel-Pro upper intake gasket (both parts from Advance Auto), the job came in at under 40 bucks total. Wonder how much it would have cost for the same diagnosis and repair at a dealership?
  #45
Old 01-10-2005, 07:58 PM
mstoned1's Avatar
mstoned1
mstoned1 is offline
you might end up having to change the shaft yet i have seen quite a few of these start making the same scratching sound that you described and it was the shaft. easy way to test is to run the motor with the sensor off and disconected if still noise replace the whole shaft
hagen
Quick Reply: Camshaft Sensor/Synchronizer Replacement
