Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #106 (permalink)
Old 11-05-2007, 01:22 PM
fordborn's Avatar
fordborn has a very good reputation on FTE.fordborn has a very good reputation on FTE.fordborn has a very good reputation on FTE.fordborn has a very good reputation on FTE.
ok here is my problem. On a 99 Ranger with the 3.0 it was running a little rough but did not get any code. All of a sudden the other day the oil pressure dropped to nothing so we towed it home. Pulled the code and found a P0340 or cam sensor code. Pulled the sensor and synchronizer and found that the teeth on the gear were gone on one section and worn to a paper thin edge on the rest of the gear. Well figured out that that would sure cause the oil pump to quit if the gear wasn't turning and would also through the code for the sensor. Now what would make the gear wear like this and is it possible the cam gear is still OK or am I looking at a replacement there also? Has anyone run into this before.
Thanks
Sponsored Links
To remove this ad, register today!
  #107 (permalink)
Old 11-05-2007, 02:26 PM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
Quote:
Thanks
A worn synchro gear like that is not all that uncommon on the 3.0L vulcan engine, as this thread illustrates. It was also somewhat of a problem for Ford back when the 3.0L had a distributor, the gear on the distributor shaft would sometimes wear down in the same manner.
It sounds like you may have shut things down in time to save the motor.
The dealer fix is to replace both the synchro shaft and camshaft as a set. On the other hand, I've heard of people just dropping in a new synchro shaft and being on their way.
You should also change the oil and filter in any event, and if you get motivated you can drop the oil pan and clean out any metal shavings that have found there way down there.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #108 (permalink)
Old 11-05-2007, 03:16 PM
fordborn's Avatar
thanks for the reply. Yes the truck was shut down immediately so I would think there should be no damage. I have already changed the oil and filter and am going to again after a about a hundred miles. We are going to try and just drop another synchronizer in and see what happens. Since the gear was worn to where it would not turn it looks like I will have no reference to align the new one up.
  #109 (permalink)
Old 12-03-2007, 12:45 PM
outdoorfriends is starting off with a positive reputation.
Hello all. I am new to this site.
I have a 2004 Ranger 3.0L. The gas milage has been going down for quite some time now. For the past several months it has idled rough. The engine light came on and according to Autozone, the #4 sparkplug was fouling out. We changed them all out. Ran okay for a while. Then it ran rough again and the light came on. This time it said 2 were fouling out so we changed the wires and all plugs again. Now its been running rough ever since. While complaining about how rough the engine was idling, the light came on. This time, Autozone said the codes read the Crankshaft positioning sensor was bad and the #4 and #6 plugs were not firing correctly. So we change out the CPS. My truck would not start. Tried diconnecting the battery to reset the computer. Still would not crank. We put the old one back on and it started right up. So we are taking back the new one and exchanging for another. Is there anything we need to do besides swaping out the sensors? From what we could tell, there was no way to adjust the sensor.
Any help would be nice.
Thank you,
Sue
  #110 (permalink)
Old 12-11-2007, 04:58 PM
mycam8u2 is starting off with a positive reputation.
1994 4.0 cps
i need to know the procedure for installing the cam pos. sensor in my explorer, i do not have any idea how the old 1 was positioned... i have read most of the post in here..
  #111 (permalink)
Old 12-11-2007, 11:42 PM
fordborn's Avatar
Quote:
take a look at this thread and post number 33. I did this with my 3.0 and it worked fine.
  #112 (permalink)
Old 01-02-2008, 08:37 AM
2020 is starting off with a positive reputation.
My Taurus is not making the squeaking noise all the time.It comes and goes,sometimes I can make a 20-30 mile round trip and it is quiet.I'm going to take a look at the sensor and hope I see something so I don't worry about having to fool with the shaft.
__________________
95 Lightning
93 Lightning
twice as fun
  #113 (permalink)
Old 01-02-2008, 04:47 PM
kent fooble is starting off with a positive reputation.
Does CMP sensor shaft remove simply by pulling? My synch assy housing is broken also, but I don't want to mess up the shaft, which seems to be holding the housing in(I already removed the clamp bolt).
  #114 (permalink)
Old 01-03-2008, 09:35 AM
The housing and shaft come out together.It's kinda like half of a dist.I took mine out yesterday and the shaft turned a bit hard.It didn't feel rough so I kept turning it and dropping liquid wrench in the little oil hole at the bottom until it turned free and then started the same thing with oil.It was turning smooth and free so I put it back in and so far so good.I was going to go ahead and replace it but my local parts store couldn't get one for a couple of days and I needed the car.If it starts making noise again,I'll order one and replace it.Autozone said 61 bucks,Ford said 123 bucks.Don't be intimidated,if you have ever stabbed a distributor you can remove and replace the sync. assy.I made sure not to turn the engine and did end up having to turn the oil pump shaft a little to get the assy to set all the way down.I put back in the same position it came out and all is well.O yea,the Autozone part included the sensor,at least that's what Joe Bob told me over the phone.
__________________
95 Lightning
93 Lightning
twice as fun
  #115 (permalink)
Old 01-04-2008, 12:59 AM
FORD RANGER is starting off with a positive reputation.
i had to put one in my ranger here a few years back. what a pain in the wallet that was! and i have 4.0L v6. before you even get started buy plenum gaskets you'll need them. because that sensor is behind all of that. and the sync tool is about $30 bucks.
i know i bought one.
ford ranger
  #116 (permalink)
Old 01-05-2008, 02:38 AM
3.0 98ranger is starting off with a positive reputation.
Yes, the Haynes manual is about 20 bucks and it has been a life saver for me, the crankshaft and camshaft positioning sensors both went out on my 98 3.0L and it was very detailed in troubleshooting and repairing.
  #117 (permalink)
Old 01-08-2008, 12:56 AM
cwtravis is starting off with a positive reputation.
Just curious,
At what mileage do these synchronizers seem to fail?
  #118 (permalink)
Old 01-08-2008, 09:41 PM
mine failed at about 125k the check engine light came on, but it ran fine.
i didn't think about it until i plugged a scanner in and got the code.
i did notice there are two different parts, one has a glass top and the other has removable sensor part of the sync.
ford ranger
  #119 (permalink)
Old 01-14-2008, 01:14 PM
reduck is starting off with a positive reputation.
Dorman CPS's Failing?
Just a quick heads up...
Please read here!
  #120 (permalink)
Old 01-14-2008, 09:00 PM
i went to the local ford dealer and got mine.
haven't had any trouble since.
ford ranger
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
