02-07-2004, 03:52 PM
steering swap
i just put a '79 high pinion open nuckle disk brake dana 60 under the front end of my 1974 f-250 supercab and the steering unit that i am attempting to swap into the truck is out of an '86 f-250. The problem that I come to is that the '86 steering tie rods have tie rod ends that are markedly smaller than that of the '79 dana 60. My question is this: Can I buy new tie rod ends at a parts store with the same diameter shaft as the previous tie rod with the bigger ends to fit mine? Also I know that I am going to have to plate the frame to make that steering gear box bolt up so I don't buckle the frame, are there any other modifications that I need to be aware of in order to do this?
