interior lights stay on - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-07-2004, 10:46 AM
rangerbud rangerbud is offline
rangerbud is starting off with a positive reputation.
Unhappy interior lights stay on
Hi, I just signed onto the forum today. I have a F 250 diesel. It is running ok, but the "door open" light stays on and the interior light also stays on. I had to take the bulb out to shut it off.
has anyone had this problem or an idea of what the problem could be.
Thanks a bunch
Old 02-07-2004, 11:17 AM
Autobahn F-250 Lariat's Avatar
Autobahn F-250 Lariat Autobahn F-250 Lariat is offline
Autobahn F-250 Lariat is starting off with a positive reputation.
Spray some WD40 into the locking mechanism this should do the trick Do a search for more info on this topic.
Manny
Munkey's Avatar
Munkey Munkey is offline
Munkey is gaining momentum as a positive member of FTE.
Soak the door latch with WD-40, open and close the door a few times, and soak it again with WD-40. This should do the trick, it's a very common problem with Super Duties.
Old 02-07-2004, 11:18 AM
Munkey's Avatar
Doh, AutoBahn got to it first!
Old 02-07-2004, 12:30 PM
DS02F250 DS02F250 is offline
DS02F250 is starting off with a positive reputation.
rangerbud,
Just in case you/we overlooked the obvious...
Did you check the dimmer switch for the dash panel? If you roll it all the way up and it clicks into place, it'll turn on the interior light. I've been guilty of leaving it on from time to time!
BTW, welcome to the forum
Old 02-07-2004, 12:33 PM
Munkey's Avatar
Old 02-08-2004, 10:23 PM
Hey guys this is really good. I appreciate your help. I surely checked everything I could find of course. The door ajar light stays on all the time the key is in the ignition now. It was sporadic until the last couple of days. I had to pull the bulb out of the dome light and the alarm is always dinging when the key is in the ignition but not running.
When you say soak the "door Latch", what does that mean exactly? I mean do I just spray a lot of wd 40 into the handle opening somewhere?
Thanks a lot!
bud
Old 02-09-2004, 12:16 AM
QuickSilver QuickSilver is offline
QuickSilver is starting off with a positive reputation.
No, spray it into the latch itself, on the inside of the door. Did the trick for me too!
Old 02-09-2004, 08:02 AM
rshober's Avatar
rshober rshober is offline
rshober is starting off with a positive reputation.
Re: interior lights stay on
Thanks a bunch
Bud, by chance do you live in F'ville? I followed some dude home on Friday and was LMAO because he kept opening and closing all his doors at every stoplight. Tried to catch up and mention the dimmer switch to no avail. Hope you were able to fix the problem...welcome to FTE
Bert
Old 02-09-2004, 08:23 AM
GT350owner GT350owner is offline
GT350owner is starting off with a positive reputation.
Also check for a bad groung on the door light switch. I have an Explorer that had the same problem. Sometimes cleaning the contacts on the switch will do it. I don't know how the F250's are but some switches in the door frame ground with the screw, nut or bolt that holds them in place. If the contact area to the truck body or the screw/bold gets corroded the circuit is interupted.
Or it can be a faulty door light switch. In the case of the Explorer I tested first and when that did not fix it I changed the switch and that did it.
Old 02-09-2004, 09:37 AM
Thanks again.
I haven't had a chance to try the latest tip yet. But some have mentioned checking the switches for grounding etc. I guess I will have to take all the door panels off since the swithes must be in the door. The swithches on the F250 are actuated (as best as I can tell) by the slider arms that are attached to the body and go into the door when it is closed.
When you say spray into the inside of the door do you mean the latch where you squeeze to open the door?
By the way I have 78000 miles on the truck. I still have the original Firestone tires on it. I have never ever come close to getting even 50,000 miles on a set of tires even for my cars. I am hoping to get 100,000 miles out of these tires.
Old 02-09-2004, 09:41 AM
Hey rshober
I wasn't in F'ville, but I was aroung Albemarle all day. Trying to buy a home somewhere in that area. I don't think I am slamming doors anymore - although I did for a few days when this first started.
By the way what does LMAO mean?
Old 02-09-2004, 09:44 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
Only the latch - not the handle. And try this first before you do anything else.
Is your SD a Super or Crew or Single?
If you get 100K and still pass inspectoin, please let us know!!
Old 02-09-2004, 12:05 PM
rshober's Avatar
Hey rshober
Laughing My A#* Off. My teenagers are teaching me this new chat room abbreviation crap.
Bert
Interior lights stay on Brad SS Excursion - King of SUVs 10 04-26-2013 08:56 AM
Interior Lights Stay ON polcat Expedition & Navigator 2 03-24-2010 08:21 PM
Interior Lights Wont Go OFF!!!!!!! ZaksEx03 Excursion - King of SUVs 5 03-03-2010 02:10 PM
Interior Lights and Running board lights stay on ratast440 Expedition & Navigator 9 11-22-2004 02:42 AM
99' F350 PSD - problem with "door ajar light staying on" Cheetah Daddy 1999 - 2003 7.3L Power Stroke Diesel 9 02-11-2003 10:39 AM
Tags
2003, duty, explorer, f150, f250, ford, interior, lights, on, prevent, stay, staying, super, v250, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
