Fuel pump relay
Thanks Bob, theres a guy in the Aerostar forum with a no start/no fuel pump that I was trying to help out. From looking at the wiring diagram it "appears" that that single wire is spliced midway between the ECA & the FP relay. But it sez something about "used during vehicle assembly" thats got me wondering. Sounds like that OTC diagnostic computer would be kind of handy to have around.
I know I can ground the EEC Fuel Pump Test Pin on my '94 SHO ( which of course is also EEC-IV) and run the pump. Here's a writeup on how it's done:
http://www.superhighoutput.com/tech_view.php?id=5
OK, I grounded self test connector and the relay clicks but the fuel pump doesn't run. The pump is just over a year old so I don't think that is the problem. Ignition switch, module, and coil are all new. Got a code 96, fuel pump circuit open, battery to PCM. Any Ideas? By the way, it's an '89 Aerostar 3.0l.
Thanks for your help,
Chuck
Chuck
Originally posted by chucknc
Thanks Bob,
The inertia switch hasn't been tripped but it may still be my problem. I'm going to pull it and check it with an ohmeter. I want to jump it and apply power to the fuel pump but I'm not sure of the best way to do that. Any ideas?
Thanks Bob,
You can do this while activating the fuel pump with the jumper
Rocklege told you about...
Good luck neighbor!!!!
Right!If I have 12 volts across inertia switch wires that pretty much leads me to the fuel pump or perhaps faulty wires between. If I don't have voltage, then it's wires between fuel pump relay and inertia switch. When I do the jumper on self test connector, the FPR clicks but no hum from fuel pump. I'm guessing the FPR is fine due to the clicking. So, I hope I'm whittling it down. Do you think I'm on the right track? Thanks for your help.
Chuck in High Point
Chuck in High Point
WOAH!!!
How are you measuring the "12V across the inertia switch"? If you
are probing the wire going to the intertia switch and the wire coming out of the inertia switch (going to the fuel pump) and
measure 12V, the inertia switch is BAD!! To verify this, ground one of your meter leads, and measure the the same wires on the
inertia switch. If you do this, and measure 12V on each wire, the
inertia switch is ok.....I hope this isn't too confusing...
Sounds like your on the right track. Keep in mind that if you don't have power to the inertia switch it could be farther upstream than the wiring between the relay and inertia switch. I think the 87s used a fusable link to provide the power to the relay for the FP, the clicking relay only means its being closed but doesn't mean you have power going through it.
