Ford Explorer Keyless Remote Programing
I'm new at this so bear with me.. I recently picked up a used remote for my 94 ford explorer. the FCC ID: GQ43VT4T DOC:1470 K763 is the same as the old one that I accidently destroyed but it doesn't work.. A friend at the senior center told me that I have to program it for my car.
Question.. Where can I obtain a program guide to do this ? There is nothing on this listed in my owners manual.
I would sure appreciate any help that you could send my way.
Thank You; JACK2001 Camry Keyless Remote Programming
1. Start with
a. No key in ignition
b. Driver's door unlocked
c. All other doors locked
d. Driver's door open
2. Insert key into ignition and remove
3. Press lock, pause, unlock (2 second total cycle) 5 times
4. Close, then open driver's door
5. Repeat lock, pause, unlock cycle 5 additional times
6. Insert key into ignition and turn from lock to "on" two
times (pause in
each location 1 second). (note: "ON" not accessory position)
7. Remove key from ignition
Locks should cycle twice. If not, start over.
8. Press lock and unlock buttons on transmitter
simultaneously for 1-2
seconds then release
9. Press lock and unlock buttons on transmitter again
simultaneously
for 1-2 seconds then release
10.Press lock alone for 1 second, then release
Locks should cycle once
11. Close Driver's door to exit program mode.
If you want to program more than one remote, repeat steps 8 - 10 with the second remote before finishing with #11.
Good luck! I had to try this many times before I got the
timing down
right. Go slower on each step rather than faster and you
will have
better luck.
1. Start with
times (pause in
simultaneously
timing down
will have
better luck.
94 Explorer keyless remote programming !!
I tried your method witk no luck,however I did get an excellent reply from another site. KSEE24.com Tony Pasco emailed me the following method... I shortened it and made it a bit easier to understand.
I'm assuming that this system only works for the 91 - 94 series but I'm not sure.
Inside the left rear compartment " where the Jack is stored" taped to a wire bundle just behind the filler tube for the rear window washer bottle. You will find a 2-pin connector unplugged and just taped there. Check the wire color to be sure ... should be gray / yellow and white / yellow.
TURN ON THE INGITION
Momentarly short these 2 pins " I used a pair of small needle nose pliers". The doors will lock and unlock.. then press any button on your remote and the doors will lock / unlock again ... Repeat ... pressing another remote button...for up to 4 remotes
TURN OFF THE INGITION you're in business!!!
This worked great for me,, I bought the vehicle used with only a single key.. I bought 2 remotes on E-BAY $14.50 and $17 .
Thanks for your reply.. Just thought that I would include what worked for me.. even if it was from another web site...
Here's an even easier way:
But good job on getting it to work!!
- Gather all your remotes that you are going to program for your truck (4 total)
- Make sure all the doors and liftgate glass are closed and unlocked
- Turn the ignition key from the "OFF" position to the "ON" position without starting the engine 5 times. Your door locks will lock then unlock, signaling that you're in programming mode.
- Press any buttons on the first remote within 5 seconds. The door locks will lock then unlock, signaling that the remote has been programmed
- Repeat the process until you're done with all the remotes
- Turn the ignition off and test the remotes by pressing any buttons on the remote
Just bought a 2002XLT. The owners only could find one key and one remote. The truck has the factory driver door keypad, but came with an aftermarket remote. The owners manual discusses the keypad as a separate feature than the remote entry.
I was wondering if I can buy a factory remote on eBay, and program it as above (is the receiver installed with the keypad?)? Thanks!
borland
borland
update to my comments above:
I bought a remote on eBay for $14 including shipping. Programmed it myself. It was new and works great.
I also removed the aftermarket remote/alarm. What a rat's nest of wires and plastic boxes!
I also partially remove the interior rear quarter trim panel and found the driver door keypad code. The 5 digit code was, as described in the owners manual, on a label attached to the control unit.
Called the local Ford dealer. They want $90 for a new second key.
borland
2002 XLT
borland
2002 XLT
Stewart_H
01-06-2024 10:21 PM
86F150302
03-13-2009 12:37 AM
waldreps
12-23-2006 09:50 AM
