Bronco II Ford Bronco II
What symptoms come from a stuck thermostat?
Old 02-06-2004, 03:40 PM
dnachristen's Avatar
dnachristen
dnachristen is offline
Just a question,
If your Thermostat is stuck open, (or missing) what problems would you encounter? (besides the obivous low water temp).
Would the vehicle run really rich? Would you get the smell of fuel in your oil?
My BII runs really rich, but sometimes it will "snap out of it" and will have more power then I know what to do with. This only lasts for a gear or two. The temp never reaches above the lower line in "Normal"
I have replaced the TPS, and had the carb partially rebuilt.
Any suggestions?
Old 02-06-2004, 04:54 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
Yes, a thermostat that is stuck open (or any other condition that causes the engine to run too cold or make the computer think it's running too cold) will cause the engine to run rich. The computer operates in warm up mode, and one of the things the computer does in warm-up mode is to run rich.
At least, that's the way the 2.9 (EFI) works, and I believe it's the same for the 2.8.
Old 02-06-2004, 08:28 PM
dnachristen
thanks!
Thanks!
Thats what I thought. but had to get backup.
Guess I need to tear into the thermostat and replace it.
thanks again!
Old 02-06-2004, 10:15 PM
JimmyJames's Avatar
JimmyJames
JimmyJames is offline
You've probably got it!
Running rich? Blowing black exhaust smoke? Gas smell in the oil too? Then I'd say you're theory is right; thermo stuck wide open.
P.S. Just in case you're not aware, BII stock thermo's have a heat rating of 185 degrees. GOOD LUCK!
Old 02-07-2004, 05:28 PM
dnachristen
As I thought!
Well, I ripped into the thermostat, and to my surprise, there wasn't one!
I got 1 185 deg thermo and stuck it in... (thanks Jimmy James for the suggestion!)
Works like a charm!
Now, I have another problem, but I will make a new thread for it... If you guys could help, please do!
Thanks again!
Old 02-08-2004, 02:14 PM
Avanti's Avatar
Avanti
Avanti is offline
running rich
If the problem continues check the vacum line to the fuel pressure regulator. Any gas in means a bad regulator and would cause rich running when started & sometimes hard to start.
JeffNJF150
15
04-18-2016 11:48 PM
aharleycpl
12-31-2015 10:35 AM
whitesdford
06-19-2012 05:57 AM
bigblack02
Modular V8 (4.6L, 5.4L)
17
05-27-2011 03:44 PM
wildjon300ci
03-24-2002 06:46 PM
Quick Reply: What symptoms come from a stuck thermostat?
