What symptoms come from a stuck thermostat? - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 02-06-2004, 03:40 PM
dnachristen dnachristen is offline
dnachristen is starting off with a positive reputation.
Just a question,
If your Thermostat is stuck open, (or missing) what problems would you encounter? (besides the obivous low water temp).
Would the vehicle run really rich? Would you get the smell of fuel in your oil?
My BII runs really rich, but sometimes it will "snap out of it" and will have more power then I know what to do with. This only lasts for a gear or two. The temp never reaches above the lower line in "Normal"
I have replaced the TPS, and had the carb partially rebuilt.
Any suggestions?
Old 02-06-2004, 04:54 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
Yes, a thermostat that is stuck open (or any other condition that causes the engine to run too cold or make the computer think it's running too cold) will cause the engine to run rich. The computer operates in warm up mode, and one of the things the computer does in warm-up mode is to run rich.
At least, that's the way the 2.9 (EFI) works, and I believe it's the same for the 2.8.
Old 02-06-2004, 08:28 PM
thanks!
Thanks!
Thats what I thought. but had to get backup.
Guess I need to tear into the thermostat and replace it.
thanks again!
Old 02-06-2004, 10:15 PM
JimmyJames JimmyJames is offline
JimmyJames is starting off with a positive reputation.
You've probably got it!
Running rich? Blowing black exhaust smoke? Gas smell in the oil too? Then I'd say you're theory is right; thermo stuck wide open.
P.S. Just in case you're not aware, BII stock thermo's have a heat rating of 185 degrees. GOOD LUCK!
Old 02-07-2004, 05:28 PM
As I thought!
Well, I ripped into the thermostat, and to my surprise, there wasn't one!
I got 1 185 deg thermo and stuck it in... (thanks Jimmy James for the suggestion!)
Works like a charm!
Now, I have another problem, but I will make a new thread for it... If you guys could help, please do!
Thanks again!
Old 02-08-2004, 02:14 PM
Avanti Avanti is offline
Avanti is starting off with a positive reputation.
running rich
If the problem continues check the vacum line to the fuel pressure regulator. Any gas in means a bad regulator and would cause rich running when started & sometimes hard to start.
Oil smells like gas JeffNJF150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 04-18-2016 11:48 PM
Heater problem not making sense aharleycpl 1987 - 1996 F150 & Larger F-Series Trucks 7 12-31-2015 10:35 AM
My truck keeps eating thermostats, help!! whitesdford 1999 - 2003 7.3L Power Stroke Diesel 6 06-19-2012 05:57 AM
Cold weather trans temp Kert0307 6.0L Power Stroke Diesel 18 01-20-2011 01:49 PM
no heat irishkev Modular V10 (6.8l) 10 12-02-2007 09:40 AM
Tags
bad, closed, condition, exhaust, explorer, ford, fuel, open, rich, smell, stuck, symptom, symptoms, thermostat, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
