Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-05-2004, 01:32 AM
algiese is starting off with a positive reputation.
98 SOHC Trouble Codes
Great insight here! Got upper and lower Intakes off to change out those leaking D-rings. Checked the IAC valve, seat looked clean. Question is... will this cure the cylinder (4,5,6) mis-fire code along with the lean burn code on 4,5 & 6? At 85K, she just started the Cold Idle RPM swing. Gas milage has been steadily dropping to 16mpg freeway. After seeing the deformed lower Manifold gaskets, I wonder about all the O2 sensor replacement advice I was getting locally. Thanks
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
