96 f250 diesel - cruise control problem - Ford Truck Enthusiasts Forums
Old 02-04-2004, 10:45 PM
tlbranth tlbranth is offline
tlbranth is starting off with a positive reputation.
This truck is new to me. It runs fine but the cruise control doesn't work. I have a Haynes manual that says it's too complicated for me to tackle but I'd like to at least see if there's continuity etc. Can anyone tell me where the cruise control box is on the vehicle and what it looks like. That'd be a good start eh? Any other info would be appreciated.
Old 02-05-2004, 07:18 AM
ATC_250SX ATC_250SX is offline
ATC_250SX is starting off with a positive reputation.
Try posting in the powerstroke desiel section, but the book is right it is very complicated, the powerstrokes injectors are all controlled by a computer, so i would think the crusecontroll is linked to the computer, not a mechanical actuator like a gas job. did you check the clock spring under the steering wheel??? that will cause the cruse not to work,
Old 02-05-2004, 11:04 PM
Clock spring? What's that? Something in where the cruise microswitches are?
Old 02-06-2004, 09:48 AM
DRH DRH is offline
DRH is starting off with a positive reputation.
I recently experienced a similar problem with my F-150. You should read my posting dated 02-04-2004 for my solution named DRH- F-150 Cruise Defect. If the cruise disabling switch is not the problem you can check for power at the cruise servo by unplugging the terminal block at the servo and testing pin no. 7 for voltage with the ignition switched on. If you do have power and the disabling switch checks O.K. then the buttons on the steering wheel may need cleaning(see previous postings) or worst of all, a bad servo. Good luck.
Old 02-06-2004, 11:04 AM
DRH, its a computer controlled powerstroke, no servo in this rig,
And the clock spring is under the sterring wheel, it allows the connections for the horn airbag and crues controll, theese wear out, and cauuse stuff not to work, there are a couple on ebay that are new and pretty cheap, and like DRH said could be a dirty switch,
Old 02-06-2004, 06:20 PM
DRH DRH is offline
ATC-250SX may be may very well be right about no servo on a PSD. However, I know it has a Cruise disabiling switch on the end of the master cylinder. I used A 97 PSD to test said switch against mine. The 97 PSD switch checked good, mine was bad. If there is any evidence of brake fluid on the outside of this switch the continuity of the switch should be checked. The switch should show a closed circuit when the brake petal is not depressed. It will show a open circuit only with the petal depressed if working properly.
Old 02-07-2004, 03:25 PM
Oh ok i see, that make sense, cruse would "Think" you had the brakes pressed down if the swith was faulty. that makes sense
Old 02-08-2004, 07:10 PM
Thanks for the ideas guys. I'll check for a disabling switch. The switches under the horn cover thingy "look" good but I'll check for continuity. Still don't get what the 'clock spring is' but maybe I'll spot something. Thank you both for your help.
Old 02-08-2004, 08:11 PM
The clock spring is the part under the steering wheel wich connects the buttons on the wheel to the steering column,
Old 02-09-2004, 09:53 PM
Thumbs up
Well that was it DRH. I checked that cutoff switch with an ohmmeter and it showed several megohms resistance. So I pulled the connector, shorted it across and the cruise worked. Just ordered the switch (which is $28 at the dealer - NAPA can't get one) so should be up and running pretty soon. Thanks for taking the time to respond.
Old 02-10-2004, 10:26 AM
DRH DRH is offline
Smile
Glad it worked out for you. NAPA did not work for me either, only FoMoCo. If you make a quick changeover you will not lose any brake fluid. I also learned something about this problem. DRH
Old 02-11-2004, 08:54 AM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
DRH/ATC_250SX,
Just FYI. On a 97 truck, even a PSD, the cruise control is actuated by a servo. Granted this is not the old style vacuum actuated servo, but a electronic servo. I have the same part on my 95. This is the device that pulls and holds the cable going to the throttle body. It is controlled by the computer to tell it how much to open and when, which is why you have the electrical connector going to it. There really is no way to test this, just better of replacing if you find nothing else wrong in the system.
Granted this was not the problem in this case, just wanted to let you know that the PSDs do in fact have control servo for the cruise control..
2000 Ford Excursion Cruise Control Problems? Mitchell_Texas Excursion - King of SUVs 36 08-22-2015 07:14 AM
Psycho Cruise Control Fleetsuper 1999 to 2016 Super Duty 3 05-04-2015 02:12 PM
2000 explorer, cruise control does not work az_r2d1 Explorer, Sport Trac, Mountaineer & Aviator 7 07-10-2012 07:56 PM
Is it possible to retrofit Cruise Control into XL? AMG-SM 1999 - 2003 7.3L Power Stroke Diesel 10 08-02-2011 09:18 AM
Where to find aftermarket cruise control for e350 kevinsky18 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-06-2007 07:24 AM
Tags
1996, 1999, 2004, 96, control, cruise, cruse, diesel, f250, f350, ford, problem, problems, servo, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
