Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-04-2004, 10:20 PM
the_ottogz is starting off with a positive reputation.
transfer case
today i was able to put my 92 exploder into 4x4, the motor worked, but when i looked to see if the front shaft was spinning it wasn't, could this be that damn motor showing a wrong positon, or could this be something more serious. its gotr 110k miles on it and the tranny runs good. i will replace fluids and take apart the shift motor totally. Has this happened to anyone else??
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-05-2004, 01:00 AM
phonebem is starting off with a positive reputation.
Try pulling the motor off and seeing if it moves when you push the button. If it doesn't we have your problem, if it does you have problems... I once accidentally switched my '95 Explorer into 4Low while it was moving and unfortunately it gutted the case.
__________________
You heal for free, your toys cost money.
  #3 (permalink)
Old 02-05-2004, 03:34 PM
about how much does a transfer case cost at a junk yard, and if i do go ahead and get one, should i just go for the manuel and make it fit my automatic. I am still going to fix the motor this week along with an oil change, i will look at the transfer case to see if it has any shrapnel in it, is thier anything else i should do to see if it is in one peice, how long does it take to swap a transfer case
  #4 (permalink)
Old 02-05-2004, 10:51 PM
I have no idea how much one cost at a salvage yard. I'll assume the motor worked, I'd advise having it checked-out first it may just be something simple like a linkage being jammed (keep your fingers crossed). One things for sure, going from an auto to a manual Tcase would be the most expensive option.
__________________
  #5 (permalink)
Old 02-05-2004, 10:55 PM
daerhldgs2 is starting off with a positive reputation.
sometimes you have to try a few times before it engages ,especially if you don't use it a lot.If it's the motor I think you can adapt a shift arm quite easily.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
