Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-09-2004, 07:33 PM
Clubwagon is starting off with a positive reputation.
You can replace the rear main seal by just pulling the transmission. I did mine while I had the transmission out for another purpose last year. Once the tranny is out it takes about 10 minutes to yank the seal and drive in another one.
Changing the pan gasket was a little more work. You don't have to pull the intake manifold as is Ford's proceedure. Instead, I jacked the motor up, dropped the pan, unbolted the oil pump and let it drop in the pan. Then worked the pan out. Replaced the gasket, worked the pan back in, bolted up the pump and pan.
I wish I had known about that gasket from Summit. That would make it a lot easier.
Steve
__________________
Steve
'95 Clubwagon XLT
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-09-2004, 07:47 PM
yama916 is starting off with a positive reputation.
so with your infomations, i guess that leak isnt that bad to fix... after the test drive i checked it again and found few droplets.. so i know its a pretty bad leak.. u guys think i can offer him 2400 for that clubwagon??? that would be an awsome deal!! )
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
