SCJ piston question - Ford Truck Enthusiasts Forums
SCJ piston question
Old 02-03-2004, 10:12 PM
tess100 tess100 is offline
tess100 is starting off with a positive reputation.
scj pistons question
are scj 429 pistons the same as 429 pistons . i am building a 429 and the pistons i got are 40 over flat top scj forged , i know my motor is 10.5 cr stock with dove heads will these pistons change this
Old 02-03-2004, 10:14 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Eye brows I think.so don't quote me
I once read that:
There are single eyebrow pistons (CJ/SCJ application)
double eyebrow pistons reg 429
Canyon style pistons (racetrack cutout) on newer 460's
Flat top no eyebrow piston
Old 02-03-2004, 11:11 PM
mudcobra mudcobra is offline
mudcobra is starting off with a positive reputation.
What is the brand and part # of your pistons????
Old 02-04-2004, 10:00 PM
speed pro dont have part number rite now
Old 02-05-2004, 10:50 AM
If your part # for your pistons is L2366, then you have the CJ/SCJ pistons. I built a 429 using these several years ago.
Old 02-05-2004, 09:29 PM
whats the dif between reg 429 &cj, scj
just wondering the difference btween 429 reg ,cj ,&scj i bhave 429 scj piston (speed pro40 over) they are flat tops with one valve releif . i am wondering what they will do to com ratio with my dove-c heads.or maybe i cant even use them in a reg 429 block, i hope i can they cost me a fortune
Old 02-06-2004, 05:26 PM
I used those same pistons when I built a 429 years ago and I used DOVE-C heads with CJ valves installed. They worked fine. I just so happened to have the original 429 piston from that motor laying handy and checked it. It had 2 valve releifs and was cast, C8VE casting number. Just my guess that the 2nd valve relief bumped the compression down .5 point. As far as the pistons working with the block, the answer is yes! Finding pump gas to burn with 11:1 compression on any engine is another story.
429/460 headers 61customcabf100 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-25-2013 10:36 PM
429 or 429SCJ ? pursang Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 22 10-06-2005 04:19 PM
460 crank 429 pistons ? tess100 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 01-02-2005 12:37 AM
429 piston ring question lowflyingbird Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 05-23-2004 10:31 PM
Replace my cast iron SCJ intake with an aluminum one? fish_bulb Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 04-21-2004 09:23 PM
Tags
40, 429, 460, 460dove, building, cobra, dove, eyebrow, eyebrows, flat, heads, jet, piston, pistons, scj, single, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
