bronco II rear leaf springs
I have a question about this topic because I want to do the same thing to my truck...
Do I have to put bigger shocks on the rear and do I have to put Bronco II U bolts and other leaf hardware on the Explorer leaf springs or put the Explorer U Bolts and leaf hardware on the Explorer leafs?
Another thing to consider, I was all set to do the swap on mine until I saw how rusty all the junk yard ones were (I'm in Michigan and there's a lot of salt on our roads). I decided not to go through the trouble of putting on rusty explorer leafs that are probably nearing the end of their life anyway. For the time and effort I think the new replacement leafs offered by Jeff's Bronco Graveyard for $235 (bushings included) are a better choice. They're listed as heavy duty so my feeling is they will sag a little less and might provide a similar lift to what the explorer leafs would. I'll be buying/installing them next winter. Just my 2 cents.
You will not need longer shocks for the 1.5"-2" lift the explorer leafs will give you. Your Bronco II U-bolts would work, except that they are almost always rusted too badly to reuse. If the U-bolts have been on there for a while it's a good idea just to plan on replacing them rather than getting stuck with everything apart and needing them. And you might consider new spring and shackle bushings too while you've gone to all the work of removing the leafs.
Or does it really matter will the Explorer hardware work on my Bronco II?
If you need ubolts or any other hardware send me a message. We bend all our ubolts from straight rods so I can make whatever you need. You should go with new ubolts atleast. They stretch over time and cause issues down the road if you try and re use older ones.
-Junior
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
www.ATSsprings.com
-Junior
-Junior
-Junior
__________________
www.ATSsprings.com
www.ATSsprings.com
Thank you for your help.
Explore leaf spring
I was reading your guy's comments about using leaf springs from a Explorer I have a 1987 Ford Bronco 2 I was thinking about getting leaf spring helpers by reading your guy's comments what year Exploder should I be looking for to use their leaf springs
troverman
2017+ Super Duty
07-05-2017 02:02 PM
