2 dead cylinders
Pretty hard for a carb to shut off only two cylinders. If they aren't getting gas but the rest are,, then I would suggest pulling the valve cover and checking the springs and valves. Make sure all are freely moving. Could also be the lifters on those cylinders. The carb is Not the problem. Also check for any kind of seal/gasket leaks at the mating surface of the head/block and intake/head.
two dead cylinders again
everything under the valve cover looks to be working fine. my mechanic put all new intake gaskets on and them he put his holley 650 on it. it ran like a brand new truck them he put mine back on and it was a dog. when i cover the carb it does not die when i spray carb cleaner or wd forty around the idle does not pick up could it be the vaccum lines routed wrong
the rockers and everyting are working fine when you put a holley on it it runs like brand new the plug wires are new and sparking all the way to the cylinder could the vaccum be routed wrong when i cover the arb it does not die and ive sprayed everywhere trying to find a leak and i cant seem to find one i appriciate the help
Nally427
08-28-2013 04:59 PM
82F100SWB
07-22-2003 07:29 AM
Bob_VT
01-18-2003 03:30 PM
