Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 02-02-2004, 08:22 PM
Boose Boose is offline
Garage is empty, add now
Boose is starting off with a positive reputation.
Door Locks???
I have a 2000 with power door locks and when I hit the switch to lock or unlock they make the noise as if they are working but none of them lock or unlock any ideas on how to fix this
  #2 (permalink)
Old 02-04-2004, 11:25 AM
Goose721 Goose721 is offline
Goose721 is starting off with a positive reputation.
They will need to be replaced. I have replaced all of my door lock acutators. Ford designed another great way to make money off the customers with these things. It should run you about $600 bucks to have all of them replaced by ford.
  #3 (permalink)
Old 02-04-2004, 04:12 PM
Excursion1 Excursion1 is offline
Excursion1 is starting off with a positive reputation.
Do it yourself
You can have the dealer do it, but I found after searching the forum on door lock problems that you can replace the door lock actuators yourself. I am not a mechanic but found it relatively easy to do. Each actuator runs between 45 and 55 bucks.
  #4 (permalink)
Old 02-05-2004, 08:50 PM
this just sucks then I thought it might just be an adjustment since they all went out
  #5 (permalink)
Old 02-05-2004, 10:54 PM
valvestud valvestud is offline
valvestud is starting off with a positive reputation.
You can go to www.fordpartsonline.com and get the revised parts. All four are less than $150, and it take 2-3 hours to replace. Did all mine and they work great!
Joe
  #6 (permalink)
Old 04-24-2004, 01:41 AM
joerileyii joerileyii is offline
joerileyii is starting off with a positive reputation.
easy
actually I just did mine The fist door i removed the whole lock it took 30+ min. but i found out you can actually change each of them in about 10 min or less each. looking at the lock the actuators slide off so you can slide each of them off by just bending a tab. (Dont try this at home) but I found I could break the old actuators off then slide the new ones on and plug them in. So the first one took me a hour total getting that lock back in and all the conecting rods in the right place can be a bitch. The remaing doors and back hatch took me less than 30 min. once again look at what and how you are doing it and even though breaking it worked great for me I caution anyone from doing it I am sure ford wants more than a dollar for a whole lock assembly if you break it. for me total cost $175 for 5 actuators.
  #7 (permalink)
Old 04-26-2004, 09:16 PM
Napalm Napalm is offline
Napalm is starting off with a positive reputation.
That resembles a problem that I'm having with my 2000 X Limited. Where did you get the accuators from for such a good price?
Napalm
  #8 (permalink)
Old 04-28-2004, 09:53 AM
78crewcabjohn 78crewcabjohn is offline
78crewcabjohn is starting off with a positive reputation.
repair idea
I had a similar door lock problem on my 2001. I took the panel off and noticed that the plastic assembly fits in a metal slot. Replaced it in slot and it worked once and then broke again. Next time I applied a little glue to hold it in the slot and it has worked ever since... be careful applying glue...good luck
John , 01 X,78 f250 crew, 78 f150 all 4x4,s
  #9 (permalink)
Old 04-28-2004, 10:58 AM
As indicated in a post up above, go to fordpartsonline.com. The revised versions that are of a better design, and are $130-150 for the set of four doors.
Regards,
Joe
  #10 (permalink)
Old 04-28-2004, 08:57 PM
Thanks for the info. I'll try the fix first, then buy new components if it doesn't work
  #11 (permalink)
Old 04-28-2004, 09:18 PM
I would save yourself the trouble and just replace the actuators. The original design is poor and nothing but replacement fixes 'em.
Joe
  #12 (permalink)
Old 05-02-2004, 02:18 PM
CUINAK CUINAK is offline
CUINAK is starting off with a positive reputation.
here's a good link to help...
  #13 (permalink)
Old 05-02-2004, 02:27 PM
  #14 (permalink)
Old 05-02-2004, 10:33 PM
Thanks a million!!! Looks simple enough.
Napalm
  #15 (permalink)
Old 06-30-2004, 04:02 PM
Chargerkid Chargerkid is offline
Chargerkid is starting off with a positive reputation.
I noticed a month ago that my rear doors were not locking. Glad I noticed it before someone opened the doors and took all my belongings. Actually, the rear doors were not unlocking. I put another amplifier for my new doors speakers. The audio shop told me just to change the actuators. They charged me $150.00 to replace the two actuators and install. They used aftermarkets. They work great now!
__________________
2001 Ford Excursion 4x4 Black/Tan Ltd V10, tan leather interior, 285 75 16 BF Goodrich All Terrains, DVD headrest, JBL speakers, JL audio Amps.
9-21-11 262,000 miles!!!
Tags
2001, 55, door, doorlock, ele, excursion, ford, forum, lock, locks, problem, problems, repair, superduty, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
