Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-02-2004, 08:17 PM
Screamin T/A is starting off with a positive reputation.
U-joint greasing?
I just changed the front-most rear driveshaft u-joint on my truck. the u- joint had grease on it already so i installed it and went on my way. after i finished everything up, I greased the driveshaft spline zerk, and just to be safe i was going to grease the u-joint just to be safe. My problem is that when i finally got the gun onto the zerk, i could not pump it? No grease would go into it. I dont know if maybe i installed the zerk wrong or anything. now, 2 days later I hear a slight squeaking on take off, and if i feel the u-joint caps they feel warm after driving a short while. What do you think i shoudl do?
  #2 (permalink)
Old 02-02-2004, 10:25 PM
73highboy4x4 is starting off with a positive reputation.
i have had bad grease zerks with new u-joints. you might try changing the zerk. you have to make sure to grease them after you install them, they come with a little grease to keep them from rusting but after they are instaled they need to be greased again
__________________
73 F260 Highboy 4x4
78 bronco xlt
2000 expedition 4x4
calling me childish is an insult to childern everyhere
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
